Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
HR2510 display works when voltage 8.5
Reply
  #1
Old 10-31-2008, 02:23 PM
Junior Member
justflyawaynow is on a distinguished road
Default HR2510 display works when voltage 8.5
I am having display issues. The display shows all 8's, LCD's all light up.
I figured out that if I lower the voltage of my pwr supply to about 8.5vdc the display works fine. IC312(?), the 7805 voltage reg, has an output of 10v with normal pwr supply input. And it is about 5v with the pwr turned down to 8.5.
Any ideas?
I am not going to send it away to anyone. I am sure I can fix it but I need some ideas. I have sent emails to Rogerbird but he has not returned them yet, I am sure he is very busy.
I have replaced most of the cap's associated with that 7805 AND the 7808 it's attached to. I have also replaced all the caps on the display board itself.
I guess I really need to figure out why the 7805 does not put out 5 volts like it should. I have replace the 7805 as well.
Worldwide Radio Forum
  #2
Old 01-05-2009, 12:53 AM
Senior Member
Rogerbird1 is on a distinguished road
Default Voltage
Sorry, I did not receive any emails..
Send to me At Rogerbird1@aim.com
or Rogerbird1@hotmail.com
You say the 7805 is putting out 10v? what happens if you lift the output leg? is it still 10v?
remember to measure from the ground tab to the leg, some of the later chassis have isolated the ground on the regulators.
Let me know,
Roger
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
