Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
90 DAY WONDERS ??
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 01-04-2009, 01:36 PM
unit_399's Avatar
BIGSTRAPPER
unit_399 is on a distinguished road
Default 90 DAY WONDERS ??
I picked up several radios in the states over the holidays, and am in the process of freshening them up. Most of the newer radios use thick white insulators between the chassis and the driver, final and audio output transistors. Are these as good or better than mica insulators?? Are they plastic or ceramic? I figured the manufacturers use them because they are cheaper and easier to install on the assembly line than mica. I have heard them referred to as 90 day wonders. But... if they are as good as mica, then I won¨t bother to change them. Any input ????
- 399
Worldwide Radio Forum
  #2
Old 01-04-2009, 02:49 PM
mackmobile43's Avatar
Vern,Vern,Vern,Vern,Vern
mackmobile43 is on a distinguished road
Default
I would imagine they are teflon or silicone, teflon's probably ok but I would'nt trust the silicone ones in a high heat situation.
__________________
  #3
Old 01-04-2009, 04:44 PM
Diehard CBer
flamethrower is on a distinguished road
Default
I always heard that the first thing you should do to a radio is to replace them
  #4
Old 01-04-2009, 07:19 PM
unit_399's Avatar
BIGSTRAPPER
Default
FT -
That's what I heard too. I guess I will just have to bite the bullet and change them out. Thanks.
- 399
  #5
Old 01-04-2009, 07:52 PM
BANNED
freecell is an unknown quantity at this point
Default
that would be a huge mistake.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/tech-repair/31827-90-day-wonders.html
Posted By For Type Date Hits
90 DAY WONDERS ?? - Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF This thread Refback 01-04-2009 02:47 PM 1
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
