Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
142 output
Reply
  #1
Old 01-12-2009, 12:51 PM
stingray is on a distinguished road
Default 142 output
i have a 142 with a dial a watt.
all the way up it dead keys 10 with no swing, all the way down it keys 2 swings to 6. what is the problem here?
on SSB it kicks butt and swings well over 20.
Thanks for any ideas.
Worldwide Radio Forum
  #2
Old 01-12-2009, 03:02 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
depending on whos been in it ? 2 to 6 sounds OK 10 watt DK no swing sounds way to much on AM. SSB sounds about right. It's kind of hard to tell other then having it looked at.
Depending on how it was tuned ? I just can't see a 10 watt DK on one of those. Maybe a 5 or 6 with a 20 watt swing or so with the variable all the way up. Wish I could tell you more. Good luck to you
  #3
Old 01-12-2009, 05:06 PM
BANNED
freecell is an unknown quantity at this point
Default
the Cobra 142 should produce up to 20WPEP from 5W of Carrier on AM and between 25-30WPEP on SSB fully modulated into a 50ohm load. if you're making measurements with a peak reading wattmeter as you should be and it performs as you said then the transmitter and amc/alc circuits are out of alignment and mis-adjusted, respectively. there could be other problems too.
  #4
Old 01-13-2009, 10:52 PM
Senior Member
Robalo is on a distinguished road
Default
the problem is bad diode D60 just replace it
__________________
  #5
Old 10-21-2009, 02:34 PM
Junior Member
wildfire365 is on a distinguished road
Default
Hey anyone know where to get finals for cobras I have a 89XLR and a 142GTL and both need new finals
  #6
Old 10-21-2009, 02:57 PM
Junior Member
Default
FreeCell I have a 142GTL and would like to know how to get it to what you said in your message. The 142 I've had for years and need to get the finals replaced first before I can get it set up for talking. I'd appreciate it if I could get mine set up like that.
Thanks wildfire365
Reply
Bookmarks
Tags
292 radio shop, cobra 142gtl
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
