Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
shock from mic
Reply
  #1
Old 01-17-2009, 06:43 PM
Junior Member
mele is on a distinguished road
Default shock from mic
I have a new Connex 4600 with a Astatic mic.
If I turn the tx pwr up past say about 60-70% I get a lil shock from the spring at the base of the Astatic mic.
What could be the cause of this?
TIA
Mel
Worldwide Radio Forum
  #2
Old 01-17-2009, 06:54 PM
74IN's Avatar
Supporting Member
74IN is on a distinguished road
Default
Bad ground.
__________________
XDX74
  #3
Old 01-17-2009, 07:32 PM
Sonwatcher's Avatar
Senior Member
Sonwatcher is on a distinguished road
Default
Yep, the old ground snap. Between that and getting a mustache whisker caught in the screen those mics can inflict some pain !
__________________
http://www.haminfobar.co.uk
  #4
Old 01-17-2009, 10:31 PM
Senior Member
Slim is on a distinguished road
Default
"getting a mustache whisker caught in the screen those mics can inflict some pain ! "
That's a great one Ron! Can't say I've been there done that;Thankfully.LOL!!!
OUCH.....
But anyways,sounds like a proper diagnosis to me guys!
Slim.
  #5
Old 01-18-2009, 05:39 AM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
A high swr/reflected wattage problem can cause a serious shock also, such as the center conductor of the coax to the antenna not making proper contact to the antenna.
There are several ways this can happen, pl-259's not soldered on properly or I have seen a cheaper coax actually burn off inside at the pl-259 or just not make contact where it slides into the pl-239.
Another is the center conductor has broken somewhere in the coax other than at the ends.
Last but probably most important is a mistuned antenna, did you check to see if you still had an antenna? maybe someone stole it,lol never hurts to check.
  #6
Old 01-18-2009, 05:51 AM
Sonwatcher's Avatar
Senior Member
Default
OUCH.....
I have ! And the bad part about it is you don't know it till you KNOW it ! LOL !
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
