Does it matter which Shottky 1N6263 piece you get? Aren't some brands much better than others? I have 50-60 2999E tramsistors and not enough diodes to match. Need to get some more. Where do you all get them and for how much apiece? Most of the places I looked online wanted RFQ. I just need 100 or so high quality doides for right now...
As far as the recieve problem with the radio, you can try another method. If you have a mobile radio in a car, have someone drive away and keep in contact with you for radio checks. If it is really quiet on your
Rx, maybe you are just one of the lucky ones with no major static generating devices close by.
You can always try another piece of coax or another antenna.
Two cents worth...
