Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
Galaxy Melaka TX problems
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 04-30-2009, 11:33 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default Galaxy Melaka TX problems
OK,
Had this radio come in a few weeks ago. It had a recieve problem. Signals would fade down but the hash (static) levels and s-meter would stay the same. Got that fixed. It has now came back with a TX problem.
Set radio to channel 20.
If you switch so ssb mode and key mic, I have a 10 watt carrier. If you modulate that it will swing to 11 watts.shows a frequency of 26.937mhz.
Switch to am.
Dead key is 2 watts and modulates to 10 watts.
Frequency 27.205 mhz.
So on ssb it is oscillating.
Voltage checks on driver and final in AM mode
--------B-----------C------------E
TR44
RX-----0.0--------5.56---------0.0
TX----1.16--------5.15---------0.03
TR43
RX-----0.00-------5.56---------0.00
TX-----0.53-------5.7----------0.03
Voltage checks on driver and final in SSB mode
TR44
RX----0.0---------13.8----------0.0
TX----0.32--------11.71--------0.05
TR43
RX-----0.00------13.81----------0.00
TX-----0.59-------0.0-----------0.05
I have been using the DX-11 and DX 77 schematic to go through this radio.
In ssb you will notice that there is 0 volts in TX mode TR43 ? Dont think that is right.
According to voltage charts it should be 0.00 in RX and 13.0 in TX on collector.
I am about to pull my hair out with this beast.
Any ideas?
Worldwide Radio Forum
  #2
Old 04-30-2009, 12:24 PM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
Did you check the alignment of the PLL? Offsets and such? Key on SSB sounds like it is out of kilter.
BC
__________________
BC
  #3
Old 04-30-2009, 01:54 PM
Radio Tech's Avatar
Radio Operator
Default
Oh yea, Did a complete alignment check on it.
Guess you asked that because of ssb frequency being off? If so I think that is because of the final is going into oscillating.
  #4
Old 04-30-2009, 02:52 PM
Senior Member
Default
But the osc and ref freqs are stable when this is going on?
__________________
BC
  #5
Old 04-30-2009, 03:18 PM
Radio Tech's Avatar
Radio Operator
Default
Solid as a rock.
Trying to hunt down where my 13 volts is at on TX.
  #6
Old 05-01-2009, 04:11 AM
Radio Tech's Avatar
Radio Operator
Default
Heres a thought for ya.
I replaced IC4 when I was working on the RX section a while back. I just replaced it again and the radio worked fine. No carrier on ssb. Tried 3 times and was fine. The fourth time I keyed the mic, there was a carrier.
So I am off now to find voltage checkes for IC 4. Maybe there is something there that is taking out part of it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/tech-repair/33775-galaxy-melaka-transmit-problems.html
Posted By For Type Date Hits
Galaxy SSB Melaka This thread Refback 01-08-2010 06:44 PM 9
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
