Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
siltronix 1011c transmit on cb mod
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 05-15-2009, 11:26 AM
Junior Member
copclyde is on a distinguished road
Default siltronix 1011c transmit on cb mod
Does anyone have the info to make a Siltronix 1011c transmit on cb? I have a really nice one, but it has a few issues. Would like to maybe find a tech that can fix it. Its super clean. If you know of someone or have the mod please let me know. Thanks Email copclyde44@hotmail.com
Worldwide Radio Forum
  #2
Old 05-15-2009, 10:16 PM
Senior Member
kd-5-bgt is on a distinguished road
Default
I used to have a Siltronix 1011d several years back and it was modded for 11 meters.From what I remember there was a tap on the coil that is located behind the front panel just to the side of the vfo box.I am sure that there is a mod write up that you can find here somewhere and maybe if you googled it chances are really good you can locate a mod
The one that I had worked great on 11 meter ssb ,it would go AM mode but since those radios are very prone to drift they are not a very good AM rig.....but if you let the radio warm up for a while they will settle down and the drift will be bearable...very tough old radio and alot of fun to use...I do miss the one that I had.
The 1011d and I think the 1011c came factory with a 8950 tube driver but you could run a M2057 and get a bit more power out of it ...about 100 watts with the 8950 and about 150 or a bit more on a good day with the M2057
  #3
Old 05-16-2009, 06:37 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Secret CB volume 1 page 46.
(NOTE. The "After" picture in the book is wrong)
Remove cover and VFO cover .
Unsolder coil with wire on end from terminal.
Scrape enamal coating from center of coil.
Solder a short wire from coil center to where coil was removed.
Replace cover.
Be sure to use a frequency counter to recalibrate the trimmer capacitors on the two bands. The unit will now operate on the lower and upper halves of the eleven meter band.
  #4
Old 07-14-2009, 10:47 PM
Junior Member
ncdoggiestyle is on a distinguished road
Default siltronic 1011d mod for 11 meters
Does anybody have a smaller pic of the mod so we can see how to do this?
  #5
Old 07-15-2009, 12:38 AM
MisterFatty's Avatar
Poppin Fresh!
MisterFatty is on a distinguished road
Default
Quote:
Pixresizer is a completely free easy to use program which will allow yout to easily resize most digital images.
Image resizing, do it with PIXresizer
or check the links resized to 800x600
http://img162.imageshack.us/i/picture056.jpg/
http://img154.imageshack.us/i/picture057k.jpg/
  #6
Old 10-27-2009, 05:53 PM
Junior Member
mustang69 is on a distinguished road
Default
can any body provide me the modification to transmit on cb using a
siltronix commache 1011d thanks marc
  #7
Old 10-27-2009, 07:40 PM
Robb's Avatar
WWRF Moderator
Robb is on a distinguished road
Default
My Siltronix VFO model 90 has a problem - it is hooked up to a SBE Console II. It will tune the regular 40 channels; but it doesn't work on the upper freqs. Is there a 'quick fix' for this? I tried to set it with my freq counter and got nothing for the upper freqs. The adjustable cap doesn't seem to work - or am I to adjust something else first?
I'd like to get it working spiffy, as it is a very nice radio. I got it with the SBE power mic; sounds incredible on SSB or AM! Just no upper freqs. The S/RF meter also backwards modulates. It is kinda annoying, and I know there is a fix for that too. Just can't find it anymore...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...WR-11 San Jose CA - Standing By..."
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/tech-repair/34051-siltronix-1011c-transmit-citizens-band-radio-mod.html
Posted By For Type Date Hits
siltronix 1011c transmit on cb mod This thread Refback 05-18-2009 05:32 AM 1
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
