Cobra 29 - R56 smoking  | |
05-21-2009, 12:14 AM
| | Senior Member | | Join Date: Apr 2002
| | Cobra 29 - R56 smoking I got a radio to look at today...It has almost no output and it seems that the final is out. Also, when you key for a few seconds, R56 next to the final starts smoking and is clearly burnt. I'm guessing this is because the final is shorted and drawing too much current? (already looked at the schematic) Are there any other reasons why this could happen? |
05-21-2009, 01:01 AM
|  | Senior Member | | Join Date: Dec 2008 Location: Silicon Valley CA, Storm Lake IA
| | A guess - its resistance value went up?
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
05-21-2009, 06:05 AM
|  | Senior Member | | Join Date: Jun 2008 Location: South Mississippi
| | The final is shorted causing R56 to overheat. Replace the final along with the resistor....20 or 22 ohm, 1/4 watt, if I remember correctly. Don't forget the ferrite bead!!
BC
__________________ BC |
05-22-2009, 12:35 AM
| | Quote: |
| Oh yeah, it's definately shorted...I was just curious if anything could cause that resistor to burn...after looking at the schematic, I can see that's the only reason |
05-26-2009, 06:50 PM
| | Ex-Radio nut | | Join Date: May 2009 Location: Riverside, CA
| | Actually, replace it with a 3.3 ohm 1/2 watt resistor with a ferrite bead on it. This will bring the input impedance closer to what it needs to be, and also bring the transistor deeper into a class "C" stage, which will cause it to run cooler. Becuase of how the stage is modulated, there is no concern for linearlity being needed here.
EDIT: Oh also I noticed you had asked why this happened. It's because of a short in the final. Basically the final went out. Also check C56 to make sure it hasn't been tampered with and that it's still within tolerance. If D10 has been jumpered (anti spike diode) remove the jumper. If the final was shorted, it might be a good idea to replace this diode as well. It probably had quite the load on it for a few seconds. |
06-03-2009, 05:48 PM
| | Man, this radio has more than a few problems. I put it down for a few days but need to get back to it.
After replacing the final, I power on the radio for a bit and smoke starts pouring out of the area around the audio transformer and coil. The transformer is hotter than a pistol and starts melting the plastic. So I figure the transformer is fubared and replace it. I also see that the coil is hot, so I replace that while i'm there. No help. Then i notice that the solder around D8 is bubbling...I replace that, although it tested OK. Something is causing this this part of the board to draw waaay too much current apparently. I'm looking at the schematic and nothing is jumping out at me although I have a few ideas. Anyone encountered this problem before that can point me in the right direction? |
06-03-2009, 10:36 PM
|  | Senior Member | | Join Date: Mar 2006
| | what about the voltage regulator?
that one that is a TO-220 style but is not chassis mounted.
i think its a 1096 or something like that.
is that getting really hot?
does it test good using the diode test?
im just guessing and trying to learn something.
__________________ "Man shall never reach the moon, for such a quantity of gunpowder would be needed as to gravely injure the crew."
~ Children's Encyclopedia, 1926 |
06-04-2009, 01:13 PM
| | Shorted coupling capacitor, and / or rf bypass capacitor off the vcc line going to the final. It happens a lot, it could also have taken out the transformer as well. |
11-04-2009, 09:15 PM
|  | Senior Member | | Join Date: Jul 2008
| | As a follow up, picked this radio up from mol for parts, but couldn't resist trying to figure it out. The problem ended up being the low quality insulator on the final. Casual inspection would lead you to believe the insulator was still OK, but it wasn't, dead short lead to high current drain and smoke. After replacing the insulator the radio works 100%.
This was an easy to overlook problem, probably made even easier by frustration. |
11-05-2009, 12:17 PM
|  | Radio Operator | | Join Date: Sep 2008 Location: North Carolina
| | Quote:
Originally Posted by MisterFatty As a follow up, picked this radio up from mol for parts, but couldn't resist trying to figure it out. The problem ended up being the low quality insulator on the final. Casual inspection would lead you to believe the insulator was still OK, but it wasn't, dead short lead to high current drain and smoke. After replacing the insulator the radio works 100%.
This was an easy to overlook problem, probably made even easier by frustration. | Wished I had seen this 3 weeks ago!
Had one in doing the same thing. liked to pull my hair out!.
After an hour on the bench I pulled the final for the second time and saw a small hole in the mica insulator. Boy I felt dumb. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 09:46 PM. |
