Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
golden eagle mark 3 no lsb
Reply
  #1
Old 07-01-2009, 09:28 AM
kj4mqa
kj4mqa is on a distinguished road
Exclamation golden eagle mark 3 no lsb
i have a golden eagle mark 3
works fine on am and usb.off freq. by 2 kc an am.
rec on lsb but no tx any idea`s?
ive replaced some tubes still no tx on lsb.
73s kj4mqa bill
kj4mqa@yahoo.com
Worldwide Radio Forum
  #2
Old 07-01-2009, 05:03 PM
unit_399's Avatar
Bigstrapper
unit_399 is on a distinguished road
Default
Bill -
It looks to me like the carrier oscillator V1a (12AX7) is dead in the LSB mode, or the Mode Switch has an open contact in the LSB position. Since the oscillator is working in AM and USB, the tube is ok. You can check for oscillator output by putting a scope probe on the side of C6 that is connected to the mode switch. If no oscillation in LSB, check crystal CR2 (5.6480 mhz), and make sure tuning cap C2 isn't shorted. If these check OK, then check the contacts on the mode switch in the LSB position. Check all the solder joints in the area too. Good Luck.
- 399
  #3
Old 07-01-2009, 06:29 PM
kj4mqa
Default thank you
Quote:
Originally Posted by unit_399 View Post
Bill -
- 399
ok i will check it out. thanx 4 the info.
73s kj4mqa bill
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
