I use echo; I just keep the level low so it boosts modulation slightly. It is when it is too high that it sounds like garbage.
It may be as simple as a bad diode - as far as the echo is concerned. The freq counter problem sounds like a weak voltage supply. Just guesses...
Since you have the schematic for it, maybe you could just check it all out against the radio and see if someone didn't get in there and mess things up. If that doesn't work and you cannot trace the problem, I would send it off to a trusted tech. They could put a signal trace thru the whole thing and figure out where the buck stops.
A Galaxy Saturn is a very nice radio and one worth fixing - even if you may not be able to do it your self. Keep us posted of any new finds and questions. Seems that you are just getting off to a good start on fixing it...
__________________ What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770. "...The 444 in San Jose CA; the Central Gold Coast..." |
