Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
New Cobra 29LTD sticks in TX only with a mobile antenna
Reply
  #1
Old 07-03-2009, 01:21 PM
Senior Member
moleculo has disabled reputation
Default New Cobra 29LTD sticks in TX only with a mobile antenna
I have a new Cobra 29LTD with a strange problem - The radio sticks in Transmit but only when it's in a vehicle with a mobile antenna. If you use it on the base, it doesn't stick. It almost seems like an RFI problem. I did find that Cobra has a TSB about this issue, but no resolution. Does anyone know how to resolve this?
http://www.cbtricks.com/radios/cobra.../tsb_10008.pdf
Worldwide Radio Forum
  #2
Old 07-03-2009, 03:18 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Does sound like RF in the shack, or in the vehicle anyway. I'd put a choke in the positive power lead as close to the radio as possible just to see what happens.
Stock radio? No modifications at all? No amplifier? Coax and connectors absolutely ok?
Since according to the topic title, it "sticks in TX", maybe you could move to OK, NM or LA? (sorry... )
(From that link, it sounds like Cobra is pretty clueless, too.)
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #3
Old 07-03-2009, 03:41 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
I'd agree withe Beetle, as far as the RF in the vehicle.
Since most modern day CB's no longer use a relay to kick the TX circuit on, they have gone to a diode switching circuit - instead. Something in that circuit doesn't' respond well to excessive RF - obviously. The Cobra bulletin also pointed out that grounding was another feature to this problem. Between these two diagnoses -and the RF sensitive circuit- one must conclude a bad ground in this circuit. Perhaps due tho the soundtracker circuit - since earlier 29LTD didn't have such - nor this problem.
I'm no tech; but that is what makes sense to me...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9...no linear power
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770...no linear power
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
