Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
Cobra 148 Need Help!!!
Reply
  #1
Old 10-12-2009, 12:37 AM
Senior Member
15minigrass is on a distinguished road
Default Cobra 148 Need Help!!!
Just got a Malaysian made 148. The ground(Neg) side was grounded. I guess someone hooked it up backwards. clipped all the safety green protection capasitors and still didnt work. I think the neg connection from the neg pin to the board got burnt or disconnected in some way. So I jumped a wire from the one of the metal cans with solder on it to the Neg pin and it powered up. So I got the wife to talk on the radio on the base and I drove to the dump. It sounded scratchy on AM and cant even make out what she was saying. I think this was used on a boat too as the green lining on the solder side of the board was corroded and was pealing off. I would like to try and fix it but I figured Id ask around for help before jumping right into it and cause more damage. If not, I might have to send it in for repaire.
Ill try to get some pix of it and maybe even a Video of how it sounds. Thanx. James....
__________________
Mobile:
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Soon to be "COBRA 2000"
Pyramid 25 Amp P.S.
partly assembeled Starduster/ works well too, 1.3:1 SWR....
Worldwide Radio Forum
  #2
Old 10-12-2009, 12:49 AM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
sounds like it desperately needs an allignment and a good going over. I wouldnt run that without replacing the protection rectifier diodes if your not sure what happen to begin with this could be a real hazzard I wouldnt go tweaking until thats all replaced because if you have an oops or short something you will cause more damage than what the radios even worth spending on as far as fixing.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #3
Old 10-12-2009, 01:06 AM
Senior Member
Default
Thanx Tony guess Ill send it in for repaire.... James....
Quote:
__________________
Mobile:
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Pyramid 25 Amp P.S.
  #4
Old 10-12-2009, 01:43 AM
74IN's Avatar
Supporting Member
74IN is on a distinguished road
Default
The reverse polarity diode is probably shot.
Grounding by other means probably will make things act haywire.
Look at the board near the power connector and there will be a diode that might look bad. It should be oriented parallel to the back of the radio.
You can clip it and things will work OK, but any time you eff up again will ruin the radio.
__________________
XDX74
  #5
Old 10-12-2009, 11:35 AM
Senior Member
Default
Thats the first thing I did. snip it nothing. snipped the green ones then it worked. Had to run a diffrent ground to the pin thou...
Thanx guys. Aloha jim. Off to the doc it goes....
__________________
Mobile:
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Pyramid 25 Amp P.S.
  #6
Old 10-12-2009, 10:11 PM
Senior Member
Default
Oh Hell. Took the bottom cover off plugged it in gave it one sweet whistel in the mike and bzzzttpoofblnik!!! Blew D44. I was wondering what was lighting up on the board I unkeyed too late, melted the leg end of the diode.
Off to the Hospital she goes!!!!
__________________
Mobile:
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Pyramid 25 Amp P.S.
  #7
Old 10-12-2009, 10:49 PM
TonyV225's Avatar
Senior Member
Default
Yupp without knowing whats all been done or whats happened to it its probally less of a headche just to send it off to someone whos good and knows that radio well.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cobra 148 gtl chan display mod SHOCKER RADIO AND RADIO RELATED MODIFICATIONS 4 10-13-2009 11:36 AM
Philippines Made Cobra 148 GTL Mods iceman78 RADIO AND RADIO RELATED MODIFICATIONS 5 10-12-2009 04:50 PM
New Cobra 148 GTL OPCART CB Band and CB Radios 11 09-03-2009 07:44 AM
new face plate for my older cobra 148 gtl jp196400 CB Band and CB Radios 6 05-06-2009 01:44 AM
Cobra 148 GTL no audio iceman78 CB Band and CB Radios 2 03-07-2009 04:30 PM
Powered by vBulletin®
