Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
cobra 2000gtl off freq's
Reply
  #1
Old 10-16-2009, 12:50 PM
cbkidd1 is on a distinguished road
Question cobra 2000gtl off freq's
Hi, I just got a cobra 2000gtl. And when i transmit the freq counter is showing 1kc off So if i am receiving on 27.0750 When i key. The freq counter shows 27.0751 My question is can i adjust L31 witch is the am tx freq can. Will this put it back on freq? Thanks.
Worldwide Radio Forum
  #2
Old 10-16-2009, 03:03 PM
Senior Member
moleculo has disabled reputation
Default
I'm not looking at the alignment instructions right now, but....
Before I just started turning cans, I would put it on a bench and check the appropriate test points with a sensitive frequency counter. You might be able to get it close by doing what you're suggesting, but you also might screw it up worse.
  #3
Old 10-16-2009, 03:23 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
I wouldn't use the frequency (display) as a frequency counter.
__________________
I U 212
  #4
Old 10-16-2009, 03:57 PM
Default
Thanks guys for the help.
  #5
Old 10-16-2009, 04:09 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Just a quick point: if the display reads 27.0751, that's only 100 Hz away from 27.075. Not "1kc".
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #6
Old 10-17-2009, 09:46 AM
Default
Sorry about that. I did not think that it was that far off to make a difference in my signal.Guess i will have a alignment done. thanks.
  #7
Old 10-17-2009, 10:15 AM
Junior Member
Big Dummy 123 is on a distinguished road
Default
I have 2 148f they do the same ting i is un toughed still in the box . That amount i belive is not enough to worry about no one on the othe end wont neve see or hear it being off hook up a good freq counter its prob not off thanks Ben
  #8
Old 10-17-2009, 11:09 AM
Default
Thanks ben. That's kind of what i was thinking.
  #9
Old 10-24-2009, 06:04 AM
jazzsinger's Avatar
Senior Member
jazzsinger is on a distinguished road
Default
If your only using the radio on AM then 100 hz is nothing and will never be noticed except for someone who's radio is further off in the opposite direction.
On ssb where frequency is more critical it is only slightly off and whilst aligning it with a good freq counter may get it spot on at the time as soon as the ambient temperature drops/rises significantly the radio will go off freq again as most cb's have oscillators that are temperature sensitive.I've seen radios that have been aligned in a cool room even after being allowed to heat to operating temperature move frequency when being used at operating temperature on a hot summers day,there is nothing you can do about that except use central heating to keep your room at a steady temperature which is a bit much for a cb and useless in the summer when the ambient temperature goes way above what would be comfortable.
its also very common to find radios straight out the box not bang on frequency,allowing for fcc specified frequency tolerance of the radio,manufacturers test equipment tolerance too,the person aligning it doing a good job,the fact its aligned in countries usually much hotter than ours(although that depends on where you live),and vibrations through shipping not to mention the fact most cb's are cheap made with cheap components its surprising they are actually as close as some are.
you have to ask yourself this,its not too far off,can I live with it or if I do it myself and f@ck it up am I willing to pay a tech to fix it? which a) isn't cheap and b) from what I've read on this and other forums some techs in the states would do a worse job than you because they ain't got the knowledge or the right test equipment.And can you guarantee they won't start clipping limiters or doing other stupid shit while they are in there.
its a very risky proposition letting anyone inside your radio if you don't know their capabilities.If they do f@ck it up then you have too pay a better tech even more money to fix their crap work which ends up in you paying large amounts for a job that should cost pennies.
Some food for thought for you.
  #10
Old 10-24-2009, 09:56 AM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Being off by only 100 Hz,I would leave it alone. You can really mess things up by not knowing what you are doing and by using test gear that is not calibrated. Besides, by turning the AM pot it will do nothing for thr SSB oscillators and SSB is where the most differance would be seen. Leave it.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RFX-75 on Cobra 2000GTL Stump31 CB Band and CB Radios 3 10-09-2009 02:56 AM
LesComm 8719-192 Expa kit, Cobra 148GTL & 2000GTL TonyV225 General CB Services Discussion 9 10-04-2009 08:46 AM
Brand New Reproduction Cobra 2000GTL Due Out This Fall !!! Cotton Mouth CB Band and CB Radios 12 07-28-2009 04:07 PM
need help fixing cobra 200gtl for 26mhz freqs ending in zero on tx and rx hamguy2 Tech, & Repair 1 10-27-2008 09:16 PM
cobra 2000gtl channel kit/mod???which is better?? slim cdx285 Tech, & Repair 3 04-09-2004 12:33 AM
Powered by vBulletin®
