Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
connex 4400
Reply
  #11
Old 11-02-2009, 08:10 AM
Senior Member
dxhound is on a distinguished road
Default
Theres an IC (Chip) located on the side of the chasis. Its 8 legs in a row. The chip will read ta7222ap. Resolder the legs of this IC to the board. And for that matter resolder all the transistors that are mounted to the chasis. This is the number one cause for galaxy/connex failures. The chasis and PCB flex from vibration and temperature difference and litterally pull the legs right off the pcb's. Do this and your problem will be solved! right now all you did was allow the leg to touch the solder joint but it doesnt have a good contact. The problem will show again on cold mornings. GL
Worldwide Radio Forum
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Retailers Breakin the Law? C2 FCC & ARRL Activity 170 10-18-2009 09:39 PM
connex 4400 hp embalmer42 CB Band and CB Radios 1 12-06-2004 12:48 PM
connex or galaxy?? NorthStar34 CB Band and CB Radios 2 08-23-2004 08:50 PM
Installing Connex board and RGR beep in a PC78LTW trains6969 CB Band and CB Radios 0 05-07-2002 08:33 AM
Powered by vBulletin®
