Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
connex 4400
Reply
  #1
Old 10-16-2009, 06:07 PM
Junior Member
noman is on a distinguished road
Default connex 4400
Hello I'm new to the forum.
A friend has a Connex 4400. He started having problems with the he said it
was the mike but I'm thinking coax. He kept talking on it now it won't transmit or receive.
He said before it quit it slowly started getting quieter and quieter. Like someone was turning down the volume. Any ideas on what happened to it?
Worldwide Radio Forum
  #2
Old 10-20-2009, 04:23 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
noman,
From what you said it sounds like it took out the final stage. Do you have a watt meter?
Has the SWR on the antenna been checked?
The finals can short and also take down the receive.
Does the radio show any power out on the S/RF meter?
  #3
Old 10-22-2009, 05:57 PM
Junior Member
Default
I haven't looked at the radio. He's not going to fix it so I thought about buying it and fixing it.
  #4
Old 10-22-2009, 08:45 PM
Junior Member
alumacraftmvtek is on a distinguished road
Default
i have a 4300 doing the same thing, not very literate at this any help is appreciated
  #5
Old 10-22-2009, 08:48 PM
Junior Member
Default
this is problem i posted on cbtrix.com
my 4300 is about 3yrs old, don't use everyday sometime months between use. primarily for hunting. it is mounted in my vehicle attached to wilson 5000. Radio has worked fine up till now. When i turn it on initially it is full volume no matter where volume know is set to. Within 2 minutes it quiets down to a whisper almost and i can turn the squelch knob and that does nothing. I say it doesn't recieve because i cant hear anything but static really high at first turn on then gradually it quiets down by itself. I can key mike and it breaks squelch and my meter will swing but i can't tell if i am getting out. Please any help would be nice and i am not very literate to some of the terms i have read here, so just bear with me if i ask questions please
  #6
Old 10-24-2009, 03:16 PM
Junior Member
Default
I'm not really sure about your problem. Try looking at your coax first, It might be getting pinched somewhere. If thats not it then have someone look at your radio.
  #7
Old 10-25-2009, 08:11 AM
Junior Member
dx77HML is on a distinguished road
Default
My findings on those radios is bad solder joints.If the lights on the radio is dim when turned on,then you can suspect a shorted final.I've owned a lot of the connex radios.First thing i'd do with one is go over all of the solder joints.Had very few problems if any at all after that.
__________________
www.monkeymade.com
  #8
Old 10-27-2009, 07:25 PM
Junior Member
Default
i think it is a cold solder joint, i took it apart at work and the board looked warped because i think they used a torque wrench to tighten the screws in it. All i did was loosen all the frame screws then snug them back down to get board out the bind and put it back together. It is working fine now. I am sure it will show again, if it does it will be time to get the solder iron out
  #9
Old 10-31-2009, 10:58 AM
Junior Member
Default
Thats good. At least it was an easy fix.
  #10
Old 10-31-2009, 11:56 AM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
crazy how siple things can be but then again itys amazing how difficult they can be at times aswell.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Retailers Breakin the Law? C2 FCC & ARRL Activity 170 10-18-2009 09:39 PM
connex 4400 hp embalmer42 CB Band and CB Radios 1 12-06-2004 12:48 PM
connex or galaxy?? NorthStar34 CB Band and CB Radios 2 08-23-2004 08:50 PM
Installing Connex board and RGR beep in a PC78LTW trains6969 CB Band and CB Radios 0 05-07-2002 08:33 AM
Powered by vBulletin®
