Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
cold solder joint
Reply
  #1
Old 10-23-2009, 04:34 PM
Oldtimer's Avatar
Senior Member
Oldtimer is on a distinguished road
Default cold solder joint
I believe I have a cold solder joint on my cobra 25.
The squelch seems to cut out after awhile.
When I push on the board it comes back up.
I know they are hard to find but any ideas what to look for.
Thanks
GOD BLESS
__________________
My Toys
Johnson Messenger 250 50th year
Connex 3300
2-Cobra 25 LTD Classics
Realistic 454 CB Fone
President Grant Export
Lafayette 625
Spark0matic
Dosey TC3001-P
KLV 550
Pyramid PS-26 KX
A-99
GOD BLESS
Worldwide Radio Forum
  #2
Old 10-23-2009, 05:37 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
WOOF!
I would iuse a 35 watt soldering iron and carefully touch all of the solder joints on that part of the board you described. If you don't want to do it - take it to a tech and have him do it. It may be a poor solder joint or a poor chassis ground - the tech will isolate it and find out. They shouldn't take longer than an hour and charge you about ~$30...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 10-23-2009, 07:27 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
open the radio up, non-speaker side and use a non-metallic probing device (toothbrush handle) and lightly tap around the board until you find an area the causes the symptoms to occur and you can usually see with a magnifier where the problem is then re-tin the points in that general area.
Tightening the board to chassis screws has cured many a radio woe.
__________________
I U 212
  #4
Old 10-23-2009, 07:48 PM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Also look for a broken connection where a component lead goes thru the board.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
PLL02A 5khz shift mod question fodendaf Home Brew & Mods 5 11-10-2009 01:36 PM
Astatic 575m6 firstradio Tuners, Mics, Meters & other Accessories 3 10-24-2008 04:11 PM
cold spray doctor Tech, & Repair 3 03-04-2007 08:06 AM
Mag delta force problem.. Splash1 CB Band and CB Radios 9 02-03-2007 01:49 AM
Galaxy 55 led fix??? BenDare2 Tech, & Repair 4 04-11-2005 07:28 PM
Powered by vBulletin®
