Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
HR 2510 NO TX WATTAGE
Reply
  #1
Old 10-29-2009, 05:03 PM
Junior Member
CBC544 is on a distinguished road
Default HR 2510 NO TX WATTAGE
Hr2510 rx good but has no tx power shows about a half watt on AM if I keep the mic keyed that half watt goes to 0 watts in a couple of seconds ,I have already replaced the final mrf497,the driver 2sc2166 also Q124 audio driver Q134 pre driver ,changed C95 and C97 and C75 ,all voltages on ic104 are correct,checked voltage on Q125,Q126 and Q136 all check out according to service manual now I am stumped any help would be great
Worldwide Radio Forum
  #2
Old 10-29-2009, 05:11 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
As a guess; I would have to say that a resistor or cap in/near the final stage is changing values under load.
Just a guess...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 10-29-2009, 06:18 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
I have one here that did the same thing!!!
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #4
Old 10-29-2009, 08:47 PM
Senior Member
dxhound is on a distinguished road
Default
Do you have an oscilloscope? If so probe the output of the final transistor at the transistor leg. Watch the power and see if it fades. If so do the same to the driver-then pre driver and so on. If it doesnt fall off at the final then it sounds like a bad filter or inductor, maybe the SWR PCB.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
hr 2510 no am audio durnig transmit pumphouse Tech, & Repair 1 10-08-2009 05:13 PM
2510 AM POWER SET UP. 190 Tech, & Repair 5 06-28-2009 08:06 AM
President HR 2510 VE3RCI Tech, & Repair 10 11-24-2008 08:39 PM
Doc's Tuned 2510 has Arrived! KyPoohCDX618 CB Band and CB Radios 1 12-25-2002 04:54 PM
HR 2510 Display Hawk CB Band and CB Radios 6 11-19-2002 08:52 AM
Powered by vBulletin®
