Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
cobra 29 with mosfet final
Reply
  #1
Old 11-02-2009, 09:13 PM
Senior Member
Number15 is on a distinguished road
Default cobra 29 with mosfet final
Did a mosfet change and followed instructions from cbtricks. Here is the problem R40 burned up so i replaced it with a new resistor (bigger) 1 watt and also replaced c20 cap next to it. Worked great then R40 gets hot and burns up again??? Need help Thanks.
__________________
Worldwide Radio Forum
  #2
Old 11-03-2009, 05:12 PM
Senior Member
moleculo has disabled reputation
Default
R40 is near the volume control, correct? The schematic that I'm looking at shows the couple capacitor you should look at is c33. Also look at C204.
Question, someone didn't happen to volt the previous final did they?
  #3
Old 11-04-2009, 01:22 PM
Senior Member
Default
Thanks i will look and replace it to see what happens. Thank u (final not volted)
__________________
  #4
Old 11-11-2009, 10:54 AM
Senior Member
Default
Found the problem bridged solder joint. lol
__________________
  #5
Old 11-11-2009, 11:54 AM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Glad you found the problem and thanks for sharing
  #6
Old 11-11-2009, 10:29 PM
Senior Member
Default
Thank u all on forum.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra 25 & 2SC1969 final Question Smokn_X2 RADIO AND RADIO RELATED MODIFICATIONS 12 04-28-2009 10:16 AM
DX959 (new MOSFET version) dual final mod? loosecannon Tech, & Repair 20 11-24-2007 07:26 PM
cobra 29 final Number15 CB Band and CB Radios 9 05-26-2007 03:28 PM
cobra 29 which final is better anixon Tech, & Repair 1 02-02-2007 08:34 PM
Cobra 21X 23 Channel Mobile? Dual Final?? broncoman529 CB Band and CB Radios 5 01-17-2006 12:45 PM
Powered by vBulletin®
