Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
90 DAY WONDERS ??
Reply
  #1
Old 11-05-2009, 08:25 PM
unit_399's Avatar
Bigstrapper
unit_399 is on a distinguished road
Default 90 DAY WONDERS ??
I have a question. Are the thick white plastic/ceramic insulators used in most new radios for the driver/final/modulator transistors as good as Mica insulators ??? I have heard the white insulators referred to as "90 day wonders" by several GOOD techs. But... I have also heard some good techs defend them and say they are better than mica. What are they made of???Plastic?? ceramic?? or what ?? I have an RCI2950 that has the white insulators, and I just added a speech processor to the unit. The driver and finals will be modulated a LOT harder now, and I need to know if changing the insulators will help the reliability. What experience have you guys had with this. Thanks.
- 399
Worldwide Radio Forum
  #2
Old 11-05-2009, 09:01 PM
MisterFatty's Avatar
Senior Member
MisterFatty is on a distinguished road
Default
Quote:
I've not investigated the heat transfer properties of various materials used so I really cannot give you a definitive answer. I will however give you my opinion on the matter.
I've edited down your post to what I feel is the most important part of your question. What exactly are they made of? the answer, your guess is probably as good as any.
This being the case it is easy to see why Mica insulators get my vote. they are easily distinguished from other types, they are very thin, and almost transparent, so it is easy to observe any imperfections which may lead to break down. and Being that they are very thin they reduce the insulation effect to a minimum and allow decent heat transfer.
Now as for the other types, and are they any good... don't know, but why risk it for such inexpensive parts? In the past some of the materials used have been horrible, hence the "90 day wonder" tag, I'm sure thermal transfer pads have progressed over the years, and some of them are probably pretty good. I believe the manufacturers use alternatives to the Mica insulators to save a few pennies on each radio.
Even some of the mica insulators are crap, the 29 I posted about in another thread appeared to have some kind of shredded and pressed Mica insulators, no doubt to save those few pennies, but they were shit.
Now I really don't know what all those other insulators are made from, and I really don't care, I would replace any of that crap with Mica at the earliest opportunity. I do know they have some type of silicon thermal transfer pads which are very good, but I can't tell it from the crappy rubber, or cheap ass plastic ones from some high quality thermal transfer material.
  #3
Old 11-06-2009, 07:37 AM
unit_399's Avatar
Bigstrapper
Default
Quote:
Thanks Fatty. I agree with you, so I replaced them. The insulators used in my 2950 aren't plastic, because they didn't melt when I heated them. Look to be some kind of ceramic. Just thought I'd let you know.
- 399
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Field Day June 27-28 HR1/K2LCT General Ham Radio Discussion 0 06-26-2009 10:15 AM
ANNUAL ARMED FORCES DAY CROSSBAND EVENT moleculo Announcements & Open Forum 1 04-21-2009 06:58 AM
Get Ready for ARRL Field Day 2009 ARRL ARRL Updates 0 03-23-2009 06:40 PM
Field Day Station Locator Service Returning for 2009 ARRL ARRL Updates 0 02-23-2009 07:11 PM
90 DAY WONDERS ?? unit_399 Tech, & Repair 4 01-04-2009 08:52 PM
Powered by vBulletin®
