Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Misc. Radio Related > Tech, & Repair
Amateur Callsign Lookup
Enter Callsign:
A-Static Mobile Max (v3.2) no power when keying up
Reply
  #1
Old 11-06-2009, 11:22 PM
Junior Member
BigJeff is on a distinguished road
Default A-Static Mobile Max (v3.2) no power when keying up
I have a a-static mobilemax, it's v3.2 with the 28 seconds of audio recording and 1 roger beep. When i key up with it powered up, the metere doesn't move, and there's no audio coming from the unit. if the power to the unit is off, the radio works fine. I tested it on a cobra 29 NW LTD & my galaxy 949, and it fails to work on either unit. The unit it setup to work with a 4pin cobra mic.
Has anyone ever encountered this before?
Worldwide Radio Forum
  #2
Old 11-07-2009, 12:22 AM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Maybe a broken wire inside the mic plug?
I've never had one of those mics...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 11-07-2009, 01:21 AM
Junior Member
Default
yeah, i've started going into it some. it's not a mic though, it's one of those a-static amp boxes that do echo/talkback/delay/powermic, adds a roger beep, & allows you to record 28 seconds of audio to replay. also audio passes through fine when the box isn't powered.
  #4
Old 11-07-2009, 01:51 AM
Rob KI6USW's Avatar
Senior Member
Default
Astatic MobileMax
That's the manual for it.
I hope that helps some.
__________________
What gear do I use?
  #5
Old 11-07-2009, 10:57 AM
Cotton Mouth's Avatar
Cotton Mouth is on a distinguished road
Default
I have a Mobile Max and have never heard of that problem before with them. But if it was me I would call Bob's CB Shop out in Strattanville, PA at 814-379-3003 and see if you can reach Bob himself and it seems like he is harder to get on the phone anymore as he has some dam good guy's in his shop now and that relieves him to do other things now but try to reach him and if no luck ask when the best time to reach him is and tell them you are having issues with the Mobile Max and need to talk to him or anyone else there that could help you like Bob and if they sorta beat around the bush and don't know for sure who you would need to talk to than tell them you will call back or leave a message and he will call you back. But he will be able to help you ut and also let you know who can still repair them if needed too.
Cotton Mouth.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FT-900 Negative Swing on AM ?? jwhawg HF Bands and HF Rigs 42 10-28-2009 12:33 PM
what to buy - base or mobile (when you have a power supply)? Snake Eyes CB Band and CB Radios 15 11-15-2007 04:09 PM
Interesting reading, datsun66 General Ham Radio Discussion 3 08-16-2007 09:16 PM
Help for RFI noise in mobile Hook948 Tech, & Repair 1 02-27-2003 04:42 AM
Powered by vBulletin®
