So you can just attach the whip to the pole and it will work...but you will do a lot better if you can create some radials. Also you'll need to check your SWR to make sure it's reasonable.
With a 102" stuck in the ground I was able to talk 35 miles and had a okay SWR. I added another antenna as a radial and it had an adjustable whip so it could adjust for SWR.
Later added some additional radials from some broken Elements I had lying around.
Silly project and didn't spend much time on it but it works amazingly well.
If I ever get some time I'll put up a real antenna again but after 4 months of positive results with this ugly duckling I'm tempted to just be lazy. Antenna has a flat match on 11 meters and under 1.7 on 10 meters,
Just don't ask me to talk into the North Pacific. No radial in that direction
When I did mine a while back I just went from the antenna mount with 4 pieces of 108" wire at an angle to the earth and taped them to the para cord I was using as guy wires. As for tuning I used a wilson antenna shaft to extend the 102 and then a file to cut the whip to length. A few guys on here had posted pics and I used them as a guide. With all the fabrication your better off saving for a ground plane or A-99 or I-max. Good luck
Thanks, Bamm.
Slanted radials seem to be the norm. Am trying to figure out why the radial in the pictures above is horziontal.
With all the money I've spent making homemade antennas, I could have my Moonraker! But it wouldn't do too good on my 15' mast.
Think of it as an inverted V dipole.Can you tell us the brand/model of the antenna used as the radial?
Also, from everything I've read and been told, when using a 102" steel whip for a base antenna the radial(s) should be slanted downward at approximately 45 degrees to achieve the desired impedance. In the antenna shown above, the radial is horizontal. Is it because the radial is a base-loaded antenna?
Still learning.
Thanks.
Still learning.
Thanks.
Good Luck!
Your probably better off setting up a dipole, or a I-10K.
I tried and tried. Got the antenna to tune well, but performance was poor at best. Your gonna need radials, and get it up as high as you can.
You may have better luck....
My attempt:
Can the radials on a ground plane be horizontal if a 1:1 balun is used?
My ground radials are even with my gutters and currently it is sitting only 15 ft above the ground You can barely see the antenna from the street. If you are having problems with a HOA and you are amateur licensed It is illegal for them to interfere with your station operation. The ARRL has started taking HOA's to court over this infringement.Tallman, I'd love one of those but my mast is too short and housing restrictions won't allow a taller one.
