360 ft. wire antenna 22db gain?
Discussion in 'Amateur Radio Antennas' started by linearone, May 1, 2009.
  1. linearone
    linearone
    Expand Collapse
    King of NY
    Apr 2, 2005
    614
    5
    I remember reading on some internet site about some end fed wire antenna that was around 360 ft. long and it showed 22db gain. Some hamster's site.
    Does this ring a bell with anybody? Id really like top find it again.
  2. SR385
    SR385
    Expand Collapse
    Mar 9, 2007
    794
    12
    Sure it might be possible at many full wavelengths long at a given frequency and terminated at the end.
    I would be highly directional and narrow in the direction of the far end of the wire though.
    I believe Cebik covered end fed wires. That's the site you want for wire antenna info.
  3. Wire Weasel
    Wire Weasel
    Expand Collapse
    Senior Moment
    Dec 13, 2008
    2,618
    160
    Yeah that might be possible but it still sounds pretty high. Longwires of this kind are also called Beverage Antennas and would need to be in a straight line and will be directional straight off the end. Guys who live out in the plains on a big piece of flat land will have several of these and switch around to obtain TX in the different directions.
  4. mackmobile43
    mackmobile43
    Expand Collapse
    Jock Supporter
    Feb 11, 2008
    6,715
    375
    How about 2 of them 90* out of phase? or stacked?(y)
  5. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    14,175
    5,492
    360 feet and 22 dB gain?? Maybe on 2m but NWIH on any HF band. My 600 foot antenna only had about 9 dB gain on 20m and that was directly inline with the antenna wire.
  6. W5LZ
    W5LZ
    Expand Collapse
    Crotchety Old Bastard
    Apr 8, 2005
    6,832
    747
    While it's possible, it's also very frequency dependent, as already posted. The part that's typically left out, the frequency/shape/circumstances is the 'kicker'. Might be possible on '440, but not on 160 meters. If you should happen to find that site, it'd be interesting to read it. - 'Doc
  7. C2
    C2
    Expand Collapse
    Aug 3, 2005
    2,409
    64
    I think that is what I read, 10 wavelengths long gives about 10 dB gain straight off the end...
  8. linearone
    linearone
    Expand Collapse
    King of NY
    Apr 2, 2005
    614
    5
    it was a while ago, I still cant find the site. I really wish i could even remember what band it was for. I guess from what you guys are saying is its not possible on 27mhz so I guess i will have to just put it out of my mind...lol
    it really sounded like something when I read it
  9. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,802
    804
    QRN, Are you sure you measured the length of your wire properly? I didn't know Canucks knew how to measure in feet :love:
  10. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    14,175
    5,492
    Hey come on now. We are bilingual didn't you know that? (y) Actually i grew up with the standard system and learned metric in middle school so it's real easy. Measuring in Smoots however takes a bit getting used too. :D
  11. Beetle
    Beetle
    Expand Collapse
    Dec 7, 2005
    2,824
    659
    1 furlong = 118.21 Smoots. (Thank you, Google!) :confused:
  12. Savoir Faire
    Savoir Faire
    Expand Collapse
    Jul 16, 2010
    16
    It is possible
    However, you will use 450 ohm antenna and a 4:1 balun and a radio with an Antenna Tuner or a Linked Coupler tuner. I know it will have much gain but again very directional and not a lot of usage.
    Do as someone else suggested in the posts. Read L.B. Cebiks years of research at Introduction
    Check out the DOUBLET instead at cebik.com. It will not have quite as much gain but it is high gain if you make it 140 feet or even 280 feet if you have enough yard or trees. Again you will need ladder line a 4 to 1 balun and an antenna tuner
    Best wishes,
    Savoir Faire is everywhere (Wheeeeeeee)
  13. N5GE
    N5GE
    Expand Collapse
    Mar 15, 2011
    5
    That's not possible.
    According to an EZNEC 5.0+ Pro model I just made the gain at ten feet above the ground on 14MHz is 8.5 dBi. At 200 feet it's 11.1 dBi.
  14. N5GE
    N5GE
    Expand Collapse
    Mar 15, 2011
    5
    What you described is a Beverage antenna. They actually have little gain and are not used for transmitting. They do however have a sharp frontal lobe at the terminated end. They are very low noise antennas and are usually used with a preamp.
    They have to be several wavelengths long to be effective.
    Amateur Radio Operator N5GE
    #14 N5GE, Mar 22, 2011
  15. Beetle
    Beetle
    Expand Collapse
    Dec 7, 2005
    2,824
    659
    You don't transmit with a Beverage antenna; they're for receiving only. (Well, okay, you COULD transmit with one, but not well at all. Make the worms nice and toasty, though.)
Share This Page
Members Online Now
  1. Snakedog33,
  2. w9cll,
  3. undertaker,
  4. dave457,
  5. ill41,
  6. Riverman71,
  7. darklife,
  8. Road Squawker
Total: 307 (members: 12, guests: 194, robots: 101)
