hey switch,
could that PCB be doublesided?
if so, and if someone replaced some parts, there is a chance that a component lead on the bottom of the board is either touching, or too close to the metal chassis under it.
maybe try removing the PCB and look underneath for signs of previous repair.
you might even find a cold solder joint or something.
i also agree that unsoldering a couple of leads from the transistors and testing them using the diode function of your multimeter is an easy first test.
freecell, you are one of the smartest people on this forum, but you are by far the least helpful.
yes, this is a technical forum.
it is not a forum for debate, unless the thread was started with that intention.
with all of your knowledge, im sure you can see that switch kit did not start this thread to create a debate.
he started it to get some help.
your primary goal seems to be proving yourself right.
that helps no one.
so, are you here to help people or not?
that helps no one.
