My Washington went from 2 1/2 swinging to 8 to, 2 1/2 with only 1 watt swing yet, it still produced 70% modulation as, it did when it was swinging 8 watts. I switched over to my sonar which normally dead key's at 2 1/2 and swings to 10 with 100% modulation. The sonar did the same thing. It still dead keying 2 1/2 but only swings about 1 watts but, still produced 100% modulation. I changed to another meter. same thing. I changed the jumpers. Same readings. I changed the 300a to a Palomar 500 elite. Same thing. I took thr amp/amps out of line hooking the Washington then the sonar straight to the meter/meters same thing only 1 watts swing. The wattage output readings with either of the amps also changed. I used to get upwards swing when I applied audio but now it's downward (with either amp). On air audio reports are good on the sonar and Washington. Any ideas? Thanks to all my friends. P.s. walways me!
