yes. generally the lower the input power the cleaner you will sound. i would do 1/2w deadkey and see how it sounds. the radio on the other end wont know the difference in power but should be able to tell if you drive it hard enough to distort.
Ok, the caps are in the mail. The only thing I'm REALLY worried about is frying my amp. It does take MRF455 and NOT SD1446. Since mackmobile43 said that different transistors require different value caps for compensation I'm worried that 820pf would be the wrong one.
Even though they are different pills do they use the same compensator cap?
I'm not trying to second guess anyone, I just don't want to break what I have.
I hope you guys can ease my worries. Bob85 if you could comment as well, it would be great.
technically the transistors capacitance should be taken into account when determining the correct compensation cap but plenty of cb amps use either 455's or 1446's with no change to cap values and work ok.
