Well I wanted to have an SSB radio as my base station I have my 19 AMP 13.8 volt power supply hooked to my JCPenny 981-6247 and I connected my Turner Super Sidekick to my radio, I was told by a forum member that these JCPenny radios were 4-pin standard, but apparently not, when I connected my Turner to my radio it squealed loudly and I immediately turned it off, after dismantling the original cheapo stock mic I found it was NOT 4-pin standard, so I rewired another cheap mic to test the radio to make sure it was not damaged, Could the radio be damaged still though? It apparently works, should I bother rewiring my mic to it now? If so should I rewire the radios mic plug or the mic?
T23
T23
