here is a link to cbtricks to put the mosfet in the 29. hope this helps. just noticed you said 13n10 not the 520. if you use the 13n10 and not the 13n10L it will still work as long as the gate voltage is about 3.5 to 3.8 volts. if you have the 13n10L the gate voltage will have to be around 1.8 volts or it will blow the mosfet.
