Colt Black Shadow SSB.......???
ben if its the 4pin version it should be regular cybernet wiring,
pin1 audio
pin2 shield
pin3 rx
pin4 tx
if you have an old uniden mic just swap pin 1 with pin 2 and swap pin 3 with pin 4
Just met someone with a Colt 485 Black shadow ssb radio. Thought if I could dig up some info I could make him an offer on it. Right now all I know is that it was made in Japan and the lot number is 30000330. No date of manufacture is labled on the unit. No idea if it transmits or even powers up. Its been sitting in a truck in the Phoenix heat that hasnt been drivin in 10 years.
there is more info on this radio in the secreat cb books here on cbtricks also. click on the link then on radio and look for colt in the listing and a lot of info on it . it has the 02a pll which makes it easy to add channels to.
Secret CB
Colt black shadow
ben i have the iroquios 40 which is the canadian version,not much on the net
It is made by midland international ,cybernet 02a board i think,it should be a standard 4 pin midland mic ,you can get a 4 pin cobra to midland mic adapter from copper to run standard 4 pin mics ..hope this helps
Reactions: BubbaRedFox
    63Sprint has left the room.
