cooling oil for dummy load
Discussion in 'Amateur Radio Antennas' started by towerdog, Jan 17, 2011.
  1. towerdog
    towerdog
    Expand Collapse
    one-niner-seven
    Nov 18, 2009
    607
    67
    What oil can be used. I would assume any oil would work so long as it is non conductive but I have yet to test any oil for conductivity.
  2. Shockwave
    Shockwave
    Expand Collapse
    Sep 19, 2009
    2,540
    750
    Mineral oil will work in a pinch but it offers less heat dissipation then transformer oil. I believe you can purchase a gallon of "dummy load oil" on eBay for a reasonable price. Do not use any standard oil. Even if it shows low conductivity at DC with your ohm meter, it can respond much differently with RF. They typically have other additives in them that can cause problems.
  3. GnG8d
    GnG8d
    Expand Collapse
    Jun 28, 2010
    2,037
    322
    How could a guy tell if he was sold transformer oil instead of peanut oil? Just curious.
  4. EDUK8TR
    EDUK8TR
    Expand Collapse
    Administrator
    Apr 6, 2005
    930
    Of course you can get the Mineral Oil at most local pharmacies. I was able to get some transformer oil for free. My electric company has a maintenance hub nearby. I simply went and asked for a gallon from the supervisor. After I explained what I wanted it for he simply had me write out and sign a note of the oils intended use. He then asked for and made a copy of my license and then had one of his crew hook me up with a gallon of the oil. It never hurts to ask.
  5. GnG8d
    GnG8d
    Expand Collapse
    Jun 28, 2010
    2,037
    322
    I'll have to hit my FIL up, he retired from the local power company here.
  6. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    13,680
    4,911
    I have used heavy mineral oil with no problems in a home made gallon sized dummy load while running an AL-80 into it. Regular cooking oils are not recommended at all and do NOT use any type of lubricating oil such as motor oil. Silicone load oil is the best to use if you can find it. Not sure what the stuff is that the power companies use, it may be silicone based.
  7. Shockwave
    Shockwave
    Expand Collapse
    Sep 19, 2009
    2,540
    750
    You could try frying some peanuts in it and see how they taste.:LOL:
  8. linearone
    linearone
    Expand Collapse
    King of NY
    Apr 2, 2005
    614
    5
    What about the pure silicone brake fluid available now? Think that would work? Like DOT-5
  9. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,796
    780
  10. GnG8d
    GnG8d
    Expand Collapse
    Jun 28, 2010
    2,037
    322
    My FIL said that they use mineral oil in the transformer shop *shrugs*
  11. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    13,680
    4,911
    Good question,one that I cannot answer. Silicone load oil is designed to efficiently transfer heat and has a very high boiling point and will not absorb water all properties that the brake fluid has however load oil is designed to be basically transparent to RF. I have no idea what the brake fluid would be like but I think I would try it at low power and carefully watch some meters and monitor heat transfer if I were to try it.
  12. jazzsinger
    jazzsinger
    Expand Collapse
    Bullshit Buster
    Jul 3, 2008
    1,749
    290
    i personally would talk to my local branch of Mc Donalds too see what spare oil they have, if the size of their fries portions (incredibly lame) is anything to go by they should have plenty spare.
    when they ask me if i want fries with my burger i generally say it would be nice if i got some fries with my fries nevermind my f@cking burger.
  13. office888
    office888
    Expand Collapse
    Jun 8, 2009
    499
    9
    Mineral oil.
    I've heard of success with non-detergent motor oil as well.
  14. sea_goin_dude
    sea_goin_dude
    Expand Collapse
    Jun 5, 2011
    13
    Well could smell like bacon frying while tuning up the rig. mmmmm just add an omlet with it. :D
    I have one of the cantenna loads but never got the oil haven't needed it should go over to alabama power and ask for a gallon of their xformer oil. These folks are pretty good to help you out if you ask and explain what it's for.
  15. TonyV225
    TonyV225
    Expand Collapse
    Apr 18, 2005
    5,823
    285
Share This Page
