galaxy 959 problems
bluecurt63
Jun 17, 2014
31
6
18
this 959 has good tx.but no receive,shows receive on the meter of the radio.but no sound, ive changed the audio chip and the caps around it still no sound
Check q30&q31.Might be wrong on these numbers but they are the 2 little transistors under meter when viewing parts side of board.
well you said the radio has good output but the PA and talkback does not work. does the radio have good TX and audio with the TX as you stated in your 1st post. can you clear up what is working. is SSB the same as AM.
yes everything works in transmit but no pa or talkback or receive the meter shows incoming signal but you cant hear any sound of any kind
I can't remember if the Galaxy radios need a mic plugged in or not so don't flame me fellas. But if it does, check the mic socket as well for a broken wire of burnt trace. And if I am wrong I apologize!! Just trying to help.
Thanks FR!! Didn't know if I was on the right track or not. Been a while since I have had a Galaxy radio.
    63Sprint has left the room.
