Allow me to start off by saying that I know there are many of y'all out there who prefer the bipolar transistors to the mosfets, but I'm not interested in that argument right now as much as I am trying to work out the problems I've created for myself in the name of learning new things.
I've been in the process of swapping a 13N10 mosfet into my Uniden 78; per the CB Tricks/EKL instructions and using the EN1230 companion part.
I removed R55 R56 and C61, soldered in the 1230 part in R56's place (in the correct direction), and left R55 and C61 "open". I did not solder in the 68pf cap on the backside of C59 (mainly because I didn't have one on hand, and because it said that the older-model Cobra 29's and 78's may not need them).
After install, my radio was putting out a 1W deadkey and swinging 7-8 PEP, and around 2W avg power.
I went back to check over my work again, and noticed I had been a little sloppy with the solder, and had bridged the gate with one leg of C60 and the drain with one leg of the L15 coil. I desoldered these connections and resoldered cleanly. However, in the process, the little foil piece that the drain pin solders to on the PCB came up, and now I can't get it to connect to the board. The radio will turn on, will receive, and the TX/RX light changes when the mic is keyed, but I have no output power at all.
To sum this up, here are my questions:
1.) How do I reattach the foil to the PCB so I can connect the drain pin of the mosfet?
2.) Should I have left that solder bridge between the mosfet and C60 and L15 alone?
3.) Surely the absence of the 68pf cap wasn't keeping the radio to only 1W DK and 7-8W PEP/2W avg?
Sorry for the wall of text, and thank you for any help
