Magnum OmegaForce S-45 HP Tuning Question
Super Briar
Sep 26, 2011
3
I'm going to be buying a Magnum OmegaForce S-45 HP in the near future. Could someone recommend a reputable CB tech I could send it to who could properly "peak & tune" it, or better yet a place to buy one that could do the same. I would prefer the latter since it would kill two birds with one stone, but if not a heads up on a good quailty tech will suffice.
Second question...I only plan on using this radio on 11 meter, would this determine exactly how it should be tweeked, other than setting it up for 11 meter only operation (I know about that part & could do that myself if need be)?
Thank you,
SB
Call Chris he will hook you up and do it right the first time. no TWEAKING or hacks.
The Radio Shop
4055 E Guasti Rd # 101, Ontario, CA 91761-1519
1(909) 390-5056 ‎
The Radio Shop
1(909) 390-5056 ‎
Big thanks...that is the fella I read about on the forum that is a whiz when it comes to properly tuning the Magnum Radios, but I forgot his name & didn't know how to contact him...I'll be sure to give him a call.
Does he also sell the Magnum Radios?
SB
SB
I'm not sure, call and ask!
Omega Magnum
Thank you,
SB
Tres bon radio,facile a utiliser sur le 11M
Check out CB magazines video on Youtube about that radio...
There's nothing that needs to be done to the S 45 HP other than the 11 Meter conversion...These radios are maxed-out right out of the box...
Chris Holland
Thank you,
SB
If you call Chris Holland, you need to tell him what kind of tune you are looking for. He does 2 kinds of tunes, one bad, one halfway decent. The problem is that unless you specifically tell him what kind of tune you are looking for, he will automatically butcher your radio, because that is what most of his customers want. If you tell him to make your radio sound crystal clear without overmodulating and tell him you want his "super receive" it will perform pretty decent. If you just drop it off without specifying how you want it, don't expect it to hear or talk too far unless you have a big base antenna.
Chris Holland in Ontario,ca great guy ! Busy tho. I can vouch he does a good job tuning.
    63Sprint has left the room.
