My coax debate
Discussion in 'General Ham Radio Discussion' started by avistar23, Feb 18, 2012.
  1. avistar23
    avistar23
    Expand Collapse
    May 17, 2005
    160
    18
    So i need some coax for my new antennas and amps
    ive used
    CNT 400
    LMR 400
    and im happy with both, runs will be 40 feet up the tower and 10 into shack, 50 total.
    i can get a good deal on 1/4 heliax, but it wont be able to make it into the radio as its too stiff, and would jumper a couple feet with LMR 400 or CNT
    ive also been looking at jefa tech coax
    what would you use, and why
  2. GnG8d
    GnG8d
    Expand Collapse
    Jun 28, 2010
    2,037
    322
    LMR400 .... because I have several hundred feet of it, it's low loss, and works to a 1" bend radius.
  3. W5LZ
    W5LZ
    Expand Collapse
    Crotchety Old Bastard
    Apr 8, 2005
    6,832
    743
    Of the choices you gave I would have to say the LMR-400. But only if this is for VHF/UHF. If it's for HF, then all three of the choices are very much 'over-kill'. Even for VHF/UHF the heliax isn't exactly reasonable.
    2 people like this.
  4. Mudfoot
    Mudfoot
    Expand Collapse
    Jun 17, 2009
    8,037
    2,451
    What he said.
  5. avistar23
    avistar23
    Expand Collapse
    May 17, 2005
    160
    18
    I have lmr on everything including my HF beam, i have 213 to my dipole, i like the LMR, but the 1/4 heliax although is quite small has nice loss figures
  6. Marconi
    Marconi
    Expand Collapse
    Usually if I can hear em' I can talk to em'.
    Oct 23, 2005
    5,207
    529
    Aw go on and go for it 23, that heliax will really get you out. Just keep us posted on how it works out.
    1 person likes this.
  7. KingCobra_CDX882
    KingCobra_CDX882
    Expand Collapse
    Mar 30, 2005
    2,036
    44
    I use Heliax LDF5-50a HF and LDF7-50a VHF through SHF
  8. mackmobile43
    mackmobile43
    Expand Collapse
    Jock Supporter
    Feb 11, 2008
    6,715
    371
    I have some *MPOWER coax if you're interested
  9. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Professional Amateur
    Staff Member
    Apr 6, 2005
    13,663
    4,894
    Yeah but you have more money than brains. :love::laugh: JK.......................well maybe.:whistle:
  10. avistar23
    avistar23
    Expand Collapse
    May 17, 2005
    160
    18
    Never heard of it?
  11. avistar23
    avistar23
    Expand Collapse
    May 17, 2005
    160
    18
    And yes those cables are far out my price range, and for a 50ft run on 144 i dont think i NEED such a low loss cable, want yes, need no.
  12. Captain Kilowatt
    Captain Kilowatt
    Expand Collapse
    Staff Member
    Apr 6, 2005
    13,663
    4,894
    Mack is just being Mack again.:blink:
  13. vo1ks
    vo1ks
    Expand Collapse
    Feb 11, 2012
    280
    47
    In order to make a suggestion on cable type, more information is needed. Output power and frequency of operation would be the first things to look at.
    How flexible does it need to be? Will it be connected to a rotating antenna or expected to blow about in the wind?
    For a run of only 50 feet you won't worry much about attenuation.
  14. avistar23
    avistar23
    Expand Collapse
    May 17, 2005
    160
    18
    One run is for the larcan, Feeding ultimately a 6m7jhv or similar antenna, N connectors both ends, no rotation fixed antennas. hardline would make it within 6 feet of radio, where a flexible cable would be used, however i have devised a way i THINK i could feed the hardline threw the wall right into the back of my larcan cabinet.
    the second run, will go to my gulph alpha antenna i ordered in my 2m dx ssb thread, again, permanently fied facing south Florida, again this could make it into the wall within 6 feet of radio and go flexible, OR, if i decide to go with a second larcan amp as i emailed you earlier, i may again be able ot hardline into the cabinet IF i get a 2m amp.
    i can take lmr400 or similar cable right into the radio.
    N connector will be used wherever possible, also considering changing connectors on the back of my 847 to N
  15. vo1ks
    vo1ks
    Expand Collapse
    Feb 11, 2012
    280
    47
    Attenuation on 50 feet of LMR400 is about 0.45dB @ 50MHz, 0.75dB @150MHz. LDF4 will be 0.22dB @ 50MHz and 0.40dB @150MHz.
    Once your signal leaves the antennna, if you find anyone that notices 0.2dB to 0.3dB signal difference he's spent too much money on test equipment. No one anywhere will ever tell the difference.
    Unless your power exceeds about 2.5kW @ 50MHz or 1.5kW @150MHz the LMR400 is entirely adequate. I wouldn't bother with the added hassle of dealing with LDF4 for what you're doing. Save your money for something else.
    Type-N connectors are considerably better than SO-239 / PL-259 connectors in every way I can think of. You can get an adapter for the back of your 847 to turn it into a Type-N. No need to open the radio. Remind me and I'll include an adapter with the other amplifier... :)
Share This Page
