Need help finding a logic hi from FT-1900R
ke7vvt
149
I am looking for a logic high from inside a Yaesu FT-1900R when the radio decides to output audio. I have a complete paper circuit diagram, but can't find a .pdf one to share. The inside is really accessible and I have been able to poke around with a logic probe at various things.
I have not been able to find any logic "lo's" that go to "hi" from when the radio is not passing audio, and when it is passing audio. I have it set up to only break squelch and pass audio when it receives a 123.0 Hz tone, so it has the "TN SQ" mode set on. I need a logic hi from this receiver to pass to an ARCOM RC210 repeater controller, which is how it knows that any audio that is coming through is OK to pass and transmit at the transmitter.
Does anyone have any ideas at what is "the usual" component inside the radio to tap into to get a logic hi for when the receiver has broke squelch?
Thanks in advance if anyone can help.
Yaesu FT-1900R, Yaesu FT1900R Mobile Transceiver
Welcome to Yaesu.com
    63Sprint has left the room.
