need kit for galaxy 959
Discussion in 'CB Radio Modifications' started by n0zna, Nov 28, 2008.
  1. n0zna
    n0zna
    Expand Collapse
    Digital master
    Nov 3, 2008
    1,256
    152
    where can i get one,73s de JW
  2. theshortcircuit
    theshortcircuit
    Expand Collapse
    Nov 22, 2008
    36
    I see the blue dots on fleabay under misc CB.
  3. ExitThirteen
    ExitThirteen
    Expand Collapse
    Grumpy, Cranky Repairman
    Apr 18, 2008
    1,521
    762
    You're probably better off snipping the yellow and gray wires the go to the channel selector (P5 and P6) and putting SPST switches inline with each wire than using a kit...those kits for the Galaxy 9xx series radios use crystals, and they can be difficult to line up.
    Just my two cents worth, but if you're still wanting a kit, go to Ebay and type in "viagra kit for galaxy" in the search box, or go where the previous poster suggested, that should put you in the right direction.
    -Exit
  4. Mongoose
    Mongoose
    Expand Collapse
    Mar 11, 2009
    138
    10
    If you want extra channels cut the yellow and gray wires and put the switches in line and you will be all set. The freq counter follows along.(y)
  5. 619 Cheshire Cat
    619 Cheshire Cat
    Expand Collapse
    Feb 23, 2009
    35
    The p5 p6 mod works well on that radio. Only down side is having 2 switches sticking out of the case.
  6. Mongoose
    Mongoose
    Expand Collapse
    Mar 11, 2009
    138
    10
    I put my switches on the back of the radio. Easy access and out of sight.
  7. 15minigrass
    15minigrass
    Expand Collapse
    Oct 30, 2006
    914
    20
  8. Warbird
    Warbird
    Expand Collapse
    Jan 1, 2009
    36
    Yes, but the P5/P6 mod is way more stable than a channel kit and much easier to align afterward.
  9. HomerBB
    HomerBB
    Expand Collapse
    Jan 4, 2009
    2,626
    455
    I did the mod with P5 and P6, 2 switches. Was easy to do and worked well. I took it out and intend to put a viagra b kit in. I do not like the mish-mash of channels scattered here and there with this switch this way and that switch that way, grab your partner swing her around oops, where'd she go, OH!, there's no channel there its back to channel 33. . .
    Does work, but does not get 40 up, and 40 down.
Share This Page
Members Online Now
  1. HARDROCK,
  2. mstevenso12,
  3. sonoma,
  4. Crusher,
  5. Ariel,
  6. 222DBFL,
  7. wavrider,
  8. BJ radionut,
  9. worldwidejack
Total: 387 (members: 10, guests: 289, robots: 88)
