Palomar 300A 2 pill
Discussion in 'Amplifiers' started by pimphand442, Jul 23, 2011.
  1. pimphand442
    pimphand442
    Expand Collapse
    Jun 11, 2011
    72
    Please help i have a Palomar 300A 2 pill mobile amp and i cant find a schematic on it anywhere i can only find tube style now the reason why i need the schematic is i got 2 new 2sc2879 for it but someone removed the rf chokes and i have new ones but not sure where to soldier the wires these were the only things missing thanks
  2. AudioShockwav
    AudioShockwav
    Expand Collapse
    Extraterrestrial Admin
    Staff Member
    Apr 6, 2005
    5,395
    1,087
    Is it a Commander 300-A?
    Or does it say Palomar...Black Face?
    jeff
  3. pimphand442
    pimphand442
    Expand Collapse
    Jun 11, 2011
    72
    palomar
    it says palomar 300a black face
  4. pimphand442
    pimphand442
    Expand Collapse
    Jun 11, 2011
    72
  5. AudioShockwav
    AudioShockwav
    Expand Collapse
    Staff Member
    Apr 6, 2005
    5,395
    1,087
    chokes?
    Or ten ohm resistor`s?
    if it is the two ten ohm resistors they go from the base of each transistor to ground.
  6. pimphand442
    pimphand442
    Expand Collapse
    Jun 11, 2011
    72
    chokes all resistors are there just input and out put tranformers wat i meant
  7. AudioShockwav
    AudioShockwav
    Expand Collapse
    Staff Member
    Apr 6, 2005
    5,395
    1,087
    I have dug around every where I can think of and can not find a Schematic for that amp.
    There where a lot of small amps made with the Palomar name.
    The closes thing I could find that fit`s the amp you describe is this one:
    Palomar 400 Service Manual
    But that amp uses 4 output transistors.
  8. mackmobile43
    mackmobile43
    Expand Collapse
    Jock Supporter
    Feb 11, 2008
    6,715
    371
    There would be only need for one choke from the input transformers to ground but need for two 10 ohm resistors from the base of the transistors to ground.
    If it's the choke missing it would go from front side of the transformer(side opposite the transistors) to ground.
    If it's the resistors they go from the base of the transistors just behind the input transformers.
    You can look at most palomars for directions as there is no difference in construction between it and any other unless the amp has biasing or switchable biasing which would require a circuit to switch out the dc grounding of the rf choke to the input transformer and switch in the bias circuit but I don't believe you'res has that.
  9. pimphand442
    pimphand442
    Expand Collapse
    Jun 11, 2011
    72
    the layour of a palomar 350hd is same layout but mine has 3 relays when i key up is when it sends 13.5v through the pills
  10. mackmobile43
    mackmobile43
    Expand Collapse
    Jock Supporter
    Feb 11, 2008
    6,715
    371
    Must have one helluva relay to power those transformers.
    Usually the voltage to the tranformer is constant and one of the relays controls the RF input to the transistors, one of the other relays is most likely a preamp and the other for activating a bias circuit.
Share This Page
Members Online Now
  1. The DB,
  2. LeapFrog,
  3. Ben Hebert,
  4. undertaker,
  5. kevin23,
  6. Cheech
Total: 479 (members: 6, guests: 370, robots: 103)
