Problem with 29 NW ltd classic
Mar 5, 2012
2
31
I just bought and installed a new cobra 29 NW ltd classic but my antenna warning light is coming on.. I've checked everything that I know and added a ground wire to the mounting bracket to the chasis and still doesn't want to work and the dimmer control only works on the meter and channel display opposed to lighting up all the functions. Same antenna and wiring worked fine for my cobra 19 plus.. any ideas or help would be great
Unless you have a damaged radio (new or not) you have a problem in your antenna system. Check for a short and put an SWR meter on it. Even if it worked (or seemed to be working correctly) or not.
The 19 has no SWR warning light. You may have had the problem and did not know it.
As far as the lights go, the dimmer is working correctly. Does not control the panel brightness.
John
Unless you check the swr, there is no sense going any further. Some antenna warning indicators light at 2-1 swr while others light at 2.5-1.
    63Sprint has left the room.
