Smallest tube amp available
Discussion in 'Amplifiers' started by Quiksilver, Jun 27, 2009.
  1. Quiksilver
    Quiksilver
    Expand Collapse
    Oct 23, 2006
    385
    17
    Just wondering what would be the smallest tube amp would be watt wise? Is it the 4CX-250B? Possibly looking into a small tube amp for the base. I had a 4CX-250B box awhile ago. Just seeing if there is something smaller out there.
    Should have stated this was for 11 meters with SSB capability.
    ****Please move to CB amp section!!!!
    #1 Quiksilver, Jun 27, 2009
  2. Wire Weasel
    Wire Weasel
    Expand Collapse
    Senior Moment
    Dec 13, 2008
    2,609
    158
    I've seen many single tube home brew amps. one 6LQ6 I believe, doing 40-50 watts. SSB is the addition of a delay circuit.
    Manufactured smallest amp? I dunno
  3. Highlander_821
    Highlander_821
    Expand Collapse
    Amour d'Ecosse
    Apr 2, 2005
    1,071
    17
    RM makes the KLV-200 Base. It has a single EL509 tube and will do 100-125 watts SSB cleanly.
  4. Challenger
    Challenger
    Expand Collapse
    Jun 4, 2009
    31
    i saw a 50 watt tube amp on the bay last night.
  5. Quiksilver
    Quiksilver
    Expand Collapse
    Oct 23, 2006
    385
    17
    Yeah,
    I'm just looking to get out of the mud if need be. 100-150W should do the trick. Don't want to disturb the neighbors, you know.
    The KLV looks like a nice little amp. 220V though. I would need to run a dedicated circuit.
  6. Highlander_821
    Highlander_821
    Expand Collapse
    Amour d'Ecosse
    Apr 2, 2005
    1,071
    17
    The model that is sold here in the US is 110 volt, not 220.
  7. Quiksilver
    Quiksilver
    Expand Collapse
    Oct 23, 2006
    385
    17
    Does the KLV-200 vip need to be modified for 11 meter use. This would be the perfect amp for my shack. I could also use it on HF.
    Also, availability. Know locations of US sales?
    Thanks!
  8. packrat
    packrat
    Expand Collapse
    Sep 24, 2008
    748
    14
    I know this is an old post, but i have a Kris Boomer two tuber, 60 watts or so low drive 11m amp with good tubes. Got it from 15minigrass. Works great. That is about the smallest I have seen.
    PR
  9. Mr Clean
    Mr Clean
    Expand Collapse
    May 21, 2005
    836
    31
    Heathkit SB 200 with just cb radio drive with a 2 watt dk 20 watts or so pep. 50 watt dk 200 watts pep out amp
  10. Hawke77
    Hawke77
    Expand Collapse
    Dec 10, 2009
    5
    I still have a "Jewel Box" that uses a 6BQ5 and Puts out about 8 to 10 watts carrier and 40 watts peak (AM.) Not so hot for sideband. :) They did make a version using an 8417, similar to a 6L6 that would put out around 50 watts.
Share This Page
