Solar charger for VX-8DR
Discussion in 'Ham Equipment' started by N0WY, Aug 12, 2010.
  1. N0WY
    N0WY
    Expand Collapse
    Aug 11, 2010
    13
    All,
    I will be section hiking part of the Appalachian Trail in Oct with another Ham and was wondering if anyone had recommendations on how to charge my new (will be here Friday) 8DR.
    The main use of the radios would be for simplex between us if we are separated and to try to hit some of the repeaters for fun. Won't be using any of the advanced features (like gps)...
    Thanks,
    Michael
  2. Luke_C
    Luke_C
    Expand Collapse
    KD0GBK
    Jul 8, 2009
    42
    I've been trying to get set up like this as well. USB charging options are slim and hard to come by, and get figured out.
    Hope to see some great solutions, I'd like them as well.
  3. Nursecosmo
    Nursecosmo
    Expand Collapse
    Oct 14, 2009
    97
  4. W5LZ
    W5LZ
    Expand Collapse
    Crotchety Old Bastard
    Apr 8, 2005
    6,832
    743
    I can see two 'problems' with solar powering a radio. The first is that the solar panel will be larger than you might think to produce adequate power. The second problem is expense. After everything is considered, solar power runs about $5 per amp of current. That's a really 'general' sort of cost figure, but about typical. Especially when on foot, a 'third' problem is carrying all that stuff.
    Huge number of variables in all that, starting with sun shine. Absolutely NOT impossible, just not very convenient.
    (Not the same by any means, but the local club has been checking about solar powering a repeater. Solar panels are not cheap, but it's all the 'other stuff' that get's complicated.)
  5. Deus
    Deus
    Expand Collapse
    Aug 25, 2010
    6
    Why not just get the AA Battery holder and bring AAs. One set will last 24 hours.
  6. Mthead
    Mthead
    Expand Collapse
    Jun 27, 2009
    3
    Deus has the right idea. AA's are light and easy. The only problem with them is broadcast power. The 4.5v from AA's will only broadcast 1W. And solar power won't cross the threshold voltage, 12V, for charging.
    I use one of those small 12V lead -acid batterys. There nice because they will charge from a variety of sources, including solar.
    Get one of the universal power supply cords. Be sure to put a fuss inline. And if you use the lead-acid for operation,(rather than charging), keep an eye on your radios volt meter. Happy hiking.
  7. Nursecosmo
    Nursecosmo
    Expand Collapse
    Oct 14, 2009
    97
    The first option which I listed in my above post is more than adequate for charging the radio's on-board battery. It has the same power output as the factory wall wort charger. You can even charge the battery while monitoring 146.52Mhz (it will restart if you attempt to transmit with the charger plugged in). At 3.5 x 6.5 inches, it will clip to the outside of your backpack, pannier, or even your hat.(y) Get two of them and operate your cell phone off of one, and your handitalkie off of the other. Get three and charge a small 3ah gel cell battery to power your 12V fan for comfortable sleeping at night. At $11.99 you can't go wrong.
  8. KC8CAY
    KC8CAY
    Expand Collapse
    Aug 25, 2010
    19
    Inaccurate
    That charger does not work at all for the VX-8R. The MaH is not enough to charge the battery...it does not even bring up the charging screen in full sunlight at 12v. DO NOT buy this solar charger if you are trying to charge the VX-8R.
  9. Nursecosmo
    Nursecosmo
    Expand Collapse
    Oct 14, 2009
    97
    Which one doesn't work? The first model listed? Just asking because by the specs, it should work. But then again it sounds like you actually have one and have used it, whereas, I haven't.
    BTW MaH generally has no meaning in regard to chargers. They are usually rated by instantaneous amperage, not by current delivered over time or reserve capacity the way batteries are rated.
  10. office888
    office888
    Expand Collapse
    Jun 8, 2009
    499
    9
    For maximum battery life, be sure to turn the backlight off.
    That 1.5w panel is probably your best bet.
    Modify the cigarette (ACC) attachment..cut it off, get the EDC-6 DC cable and attach it to the internal circuitry.
    There should be a charge controller inside the box of the solar charger to prevent it from DRAWING electricity. So yeah, wire it in place of the cig plug.
    Place the panel on top of your backpack, and hook it up to your radio.
    It'll be enough to keep it powered on receive, and to provide a small trickle charge to slowly charge your battery.
  11. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,792
    773
    I've seen these new Goal Zero kits at various outdoors shows and even Costco over the last year. They have different sized kits depending on your needs and are targeted at outdoor camping. Something like this 2.5 watt kit would probably work pretty good:
    GOAL0 GOAL ZERO Guide 10 Adventure Kit Solar Panel New! | eBay
  12. Walksindarkness
    Walksindarkness
    Expand Collapse
    Aug 21, 2011
    I have to 2nd the GOAL ZERO idea. I have the Guide 10 Adventure kit and it works wonderfully. Also isn't to heavy for backpacking.
    73s
  13. kc0zps
    kc0zps
    Expand Collapse
    May 18, 2009
    46
    2
    Are you charging it using the 12V cigarette lighter adaptor adapter?
  14. kc0zps
    kc0zps
    Expand Collapse
    May 18, 2009
    46
    2
    So I got the Goal0 Nomad 7 and the 12V cigarette lighter adaptor. I am trying to charge the Yaesu VX8R using the EDC-5B car charger. Unfortunately, its not working for me. The VX8R is at around 6.1V's and I left it plugged into the solar charger for about 24 hours. When I turned the VX8R on and it was still at 6.1V's.
    Interestingly, when the solar charger had light, the charging cradle would show "green" instead of red, even when the VX8R was at 6.1V's. Anyone know what I am doing wrong?
    EDIT: someone just suggested this. I'm going to try and connect a multimeter to the charging cradle next chance I get and see how much power is being generated in full sunlight.
    #14 kc0zps, Aug 30, 2011
  15. Moleculo
    Expand Collapse
    Administrator
    Staff Member
    Apr 14, 2002
    8,792
    773
    I was going to suggest the multimeter test as well. Let us know what you find out as I was considering one of these kits for similar purpose.
Share This Page
