Swing Kit Pro's & Con's
Discussion in 'CB Radio Modifications' started by hammer0630, Mar 9, 2012.
  1. hammer0630
    hammer0630
    Expand Collapse
    Sep 10, 2011
    474
    57
    I saw a swing kit kit on eBay with a adjustable d.k. The seller claims it comes with good instructions and photo's that anyone can do this install. For $5.50 total I purchased it. Now my question is what are the pro's and cons of these things? I have a Cobra 148GTL pushing a RM Italy KL-503 amp. If this swing kit pushes very high audio wattage into my KL-503 even with a 2 watt dk wouldn't it still cause damage?
  2. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    9,760
    1,786
    The variable power mod is the ticket for the linear running properly. If that amp will run at 1 watt; then set the radio output for that. Don't be hung up on the output numbers. No one will notice 40 watts less; they will notice a crappy sounding transmit - though.
    As far as the swing mod goes; that will depend on how much modulation%/mic gain you use. Again, a crappy loud radio sound isn't always clear - and therefore - not better. Best get a radio check from a local operator that can give you a valid report. Clean sound is always better understood either locally or even distantly . . .
    #2 Robb, Mar 10, 2012
    2 people like this.
  3. GnG8d
    GnG8d
    Expand Collapse
    Jun 28, 2010
    2,037
    322
    This is a contradiction of terms, if these amps were linear, there would be no need to run a 1/2 watt dead key.
    1 person likes this.
  4. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    9,760
    1,786
    Yes; you are right.
    Should have used the word 'amp' instead.
    But running that 'amp' according to the input specs will keep it as 'linear' as it will be possible to do.
    Think it uses 8(?) mosfets if I recall.
  5. 9C1Driver
    9C1Driver
    Expand Collapse
    Aug 13, 2008
    2,689
    579
    You can get the parts at Rat Shack for less then a buck. cbtricks.com should have the information as well. That said the old school 148's are such nice radio's they don't need a swing kit. Do a search here of the forum, lots of threads about swing kits.
  6. mr_fx
    mr_fx
    Expand Collapse
    Oct 8, 2011
    1,537
    167
    it is an 1 RM3 driving 8 RM3 mosfets (most people say the RM3 is a rebadged irf520)
  7. mackmobile43
    mackmobile43
    Expand Collapse
    Jock Supporter
    Feb 11, 2008
    6,715
    371
    I hear they're made by little people who live inside trees and they make cookies on the side.
  8. psycho
    psycho
    Expand Collapse
    Supporting Member
    Aug 25, 2006
    3,105
    848
    They also do superwackpackIIs, that's why they have to hide in trees.
  9. mr_fx
    mr_fx
    Expand Collapse
    Oct 8, 2011
    1,537
    167
    They prefer to be called Elves. :D
  10. JoeDirt
    JoeDirt
    Expand Collapse
    Dec 15, 2008
    312
    93
    Dont install a swing kit in your 148, Other radios like a Galaxy, Connex ect take to swing kits better than the 148/Grants. A 148 is a really good radio that does not need a swing kit to be a good performer. I agree with Robb do a variable power mod or just pop the top and adjust VR10, lower the dead key and play around with it a little!
  11. jon666
    jon666
    Expand Collapse
    Jan 24, 2006
    774
    152
    yeah
    get out the golden screwdriver lol
  12. wahlrite
    wahlrite
    Expand Collapse
    Jul 19, 2008
    68
    In my experience swing kits only increase wattage and not modulation.
    and since modulation is what makes you loud, not watts, I let my amplifier create the watts I am looking for.
    So in my opinion, and since most amplifiers sound better with lower drive Vs. higher drive, I keep my PEP into the amp on the lower side for best audio quality.
    Just my opinion.
Share This Page
