T match circuit
Discussion in 'Amplifiers' started by Crusher, Jul 5, 2011.
  1. Crusher
    Crusher
    Expand Collapse
    May 12, 2007
    694
    165
    Thinking about doing a T match circuit for input of a 4 tube 572B box. but never did one. Can anyone pont me in the right direction? Thanks in advance.
  2. VA3ES
    VA3ES
    Expand Collapse
    Old Buzzard
    Oct 30, 2010
    645
    65
    T-match circuits are typically used for antenna systems that have a wide range of reactances/impedances. Why do you want to use it on the input of an amp? I use a common pi-network matcher on my untuned amp. Works great.
  3. Crusher
    Crusher
    Expand Collapse
    May 12, 2007
    694
    165
    yeah i can use a couple of trimmer caps. just i seen a few using the 2 inductors and1 tuning capacitor and wanted to try it. trying to save a few dollars in parts.
  4. JoeDirt
    JoeDirt
    Expand Collapse
    Dec 15, 2008
    321
    96
    You might be able to get it low enough with just a trimmer cap.
  5. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,004
    813
  6. Crusher
    Crusher
    Expand Collapse
    May 12, 2007
    694
    165
    Checked link, thanks. Should work great.
  7. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,004
    813
    Good deal let us know how it turns out.
  8. paws264
    paws264
    Expand Collapse
    Apr 6, 2005
    647
    4
    I thought that T-network were primarily High Pass Filter; shows you what I know....
    Electrically, in your application, the "T-Match" is a paralled tuned circuit that will be fed with a Capacitor that is tapped somewhere down the coil.
    Stick with the tried and trusted Pi-network.
  9. Crusher
    Crusher
    Expand Collapse
    May 12, 2007
    694
    165
    yeah, sticking with pi circuit. Seems way simpler and more straight forward
Share This Page
Members Online Now
  1. magnuman,
  2. sonoma,
  3. Wire Weasel,
  4. crunchybobjones,
  5. camaro1,
  6. 222DBFL,
  7. worldwidejack,
  8. lost bandit,
  9. 928bolo
Total: 239 (members: 12, guests: 139, robots: 88)
