turner + 3 wiring
Oldtimer
223
9
75
Stuart Florida
I have saw the wiring for a Turner + 3 to a Cobra 25.
When I wire it up as stated and I plug it in the radio I get
a loud hum and the needle pegs to the right.
Here is the way I wired it up.
1-sh/red
2-white
3-blue
4-black
Any suggestions?
It's not the radio cause I tried it on my other Cobra 25 which is brand new.
Thanks
That is the correct wiring for that mic/radio combo, check for short circuit in the mic connector area meaning where you soldered in the connector, very small wires are hard to see sometimes.
This is from the Turner Wiring Handbook-
1-shield
2-white
3-black
4-red
1-shield
2-white
3-black
4-red
That's the same as my super sidekick (I looked inside) and I assume they like many other manufactures used different mic cords with different color wires.
1-sh/red
2-white
3-blue
4-black
Any suggestions?
Thanks
There is a switch on the bottom of the mic electronic/relay, put it in electronic position.
He has a blue wire, post factory cord?
There is a conversion in the handbook ( changing use of wires when using a 6 wire Turner for a 4 wire radio )that tells you to use the black wire in place of the blue and the red wire in the place that black would normally be when using a 6 wire.
Not sure if someone put a Turner 6 wire cord on it. My Turner CS-1 is a 6 wire.
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
