Viagra blue dot 'b' board problems
Discussion in 'General CB Services Discussion' started by Lil'Yeshua, Jan 12, 2013.
  1. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Hey guys! I just got off from work and turned my Galaxy DX-959 on to warm it up. After a few moments I heard it start to make strange sounds. The radio was showing that it was on 26.615 MHz with the freq counter going up and down in frequency close to that frequency. The lo/norm/hi switch had no effect on changing the frequency. I took the speaker cover off and unplugged the Viagra board from the radio and returned the jumpers to their original position ala' cbtricks info. The radio is operating normally now in the forty channel unmodified mode. I'd expect to get more than one month out of something likr this. My question is, does anybody know what to do with the Viagra board once it starts goofing up? P.S. I. Thought about buying a new Viagra board from DTB. :headbang
    #1 Lil'Yeshua, Jan 12, 2013
  2. camaro1
    camaro1
    Expand Collapse
    Nov 2, 2012
    981
    329
    the 959 i had all i did was cut 2 wires and install 2 switch's and i had above 40 and below 40, no board needed
    1 person likes this.
  3. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Ok
    I know. I was wanting to know if anyone else had this problem.
  4. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Plus,DTB has the radio freq adjusted to the Viagra board so it may very well have to go back to him.
  5. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Two wires.
    Does it skip some feeds like the Viagra board does?
  6. camaro1
    camaro1
    Expand Collapse
    Nov 2, 2012
    981
    329
  7. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
  8. wavrider
    wavrider
    Expand Collapse
    Jun 2, 2009
    3,084
    863
    I have modded a few 959 (interpret as I have lost count of how many).
    I use the LESSCOMM board for freq mods.
    I have had one modd that did exactly as what you are describing. I had to send the board back to LESSCOMM to get the chip re-programmed.
    Your viagra board if it uses chips for the freq mod may have lost it's programming.
  9. RADIOOMAN
    RADIOOMAN
    Expand Collapse
    Jun 1, 2012
    428
    53
    viagra blue dot 'b' board
    Lil'Yeshua
    Just for your information; To me that appears to be a symptom of a PLL circuit that has become 'UNLOCKED'
    The adjustment for this circuit might be just on the ragged edge of its range and a small tweak adjustment could cure this problem.
    RADIOOMAN
  10. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Well I unplugged the Viagra board from the radio and returned the radio's jumper back to it's original position. The radio is functioning normaly now. I don't know anything about the Viagra board. Is there something I can do to the Viagra board other than replacing it?:confused:
  11. Mudfoot
    Mudfoot
    Expand Collapse
    Jun 17, 2009
    8,114
    2,492
    Are those boards plug n' play? I thought you needed to realign the radio after you installed one.
    I've never messed with one.
  12. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Plug and play
    No,they're not. The radio has to be realigned after installing one. I took my out of the circuit loop and the radio is functioning normally again. However the frequency is a half of a kilo cycle off but not so far as to center the frequency on the channel.
    #12 Lil'Yeshua, Jan 13, 2013
  13. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    I got a email reply from Star Electronics and Communications about my failed board. In it he says:"I do not have a warranty on them. You would have to contact Ranger Radio warrenty support they are the 1 making them. To give you a heads up the viagra boards we've been getting in we had no problems with. But the galaxy 959 and 2547 have had have a resistor changed on the board to make the viagra board work correctly. The voltage to the clarifier circuit is too low."
  14. Lil'Yeshua
    Lil'Yeshua
    Expand Collapse
    Nov 22, 2012
    4,625
    283
    Just talked with the Galaxy tech about the Viagra board and what James Brown over at Star Electronics and Communications said to me about the 959's and the 2547's needing a resistor changed out to make the Viagra board run right. There's something about the clarifier voltage oh well.
  15. Robb
    Robb
    Expand Collapse
    Yup
    Dec 18, 2008
    10,277
    2,068
    Change out one single resistor?
    What are you waiting on there?
Share This Page
