Having just successfully modded a Galaxy DX-959 Mosfet Version with dual Final IRF520s....channel kit..upgraded Votalge regulator and AM Amplifier...opened clarifier...swing mod, I am now having to decide which of my radios to Mod next.
Galaxy DX949 Mosfet Version. Already has Blue Viagra-B board channel kit. Schottky diodes for better RX. Upgraded Voltage regulator. I have the 520s and all the parts to do the dual 520 final mod to this as well.
Bone stock never been even opened until I just opened Cobra 138 XLR. I almost felt bad when I looked at the screws and realized they had never seen a screwdriver. The inside is absolutely pristine and looks brandnew. Not really sure the mods available to this radio.
Also Bone stock Cobra 148 GTL. I have a Digimax Lite kit that came out of my old Cobra 148 GTL that I thought of putting in this and possibly trying to upgrade to Mosfets. I am being told that AM and LSB sound good on this radio but USB is not sounding correct. Not sure if this is a over time usage problem that I can correct or not. All of the pots on the board still are set in their factory position with the red glue unbroken. Bigger "L" pots show no sign of having seen a screwdriver.
So need some advice. If you had this radios in front of you which radio would you do and what Mods would you preform to get the most out of it?
