Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
turner +3b desk mic
Reply
  #1
Old 06-15-2011, 10:29 AM
Senior Member
tvrc18 is on a distinguished road
Default turner +3b desk mic
I have been trying to use a turner +3b with my 2510 and most contacts say the audio is not right. I have it turned way down about 8 or 9 o-clock on the tone setting. I have gone back to my stock mic and get better reports. I wonder if some of the electrolytic caps may be going bad in the turner. I always thought they worked good on ssb. I guess also they may not work good on some radios.
  #2
Old 06-15-2011, 12:15 PM
Moleculo has disabled reputation
Default
If it's like my Turner +3 (not the B version), the gain adjustment on the mic is REALLY touchy. You basically have to monitor yourself on another rig while adjusting it because if it's just a hair too high, your audio goes to crap. When you get it right though, it really can sound good.
  #3
Old 06-15-2011, 12:22 PM
Senior Member
Default
Yea it does seem to be really touchy. I have been turning it down till the ssb output shows next to nothing and then turn it up till I just starting getting full output
  #4
Old 06-15-2011, 12:42 PM
RatsoW8's Avatar
Supporting Member
RatsoW8 is on a distinguished road
Default
You can also push the mic gain button "in" on the 2510 to reduce the gain a little. If someone removed the limiter in the radio you may not be able to use the turner or any amplified mic. My 2510 was hacked before I bought it and even with the stock hand mic and the gain bitton pushed in it's very hot.
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #5
Old 06-15-2011, 04:31 PM
Senior Member
Default
I bought it new and the only mod is the frequency expansion mod. I am going to look at the caps in the mic and see how they look. I did try it turning on the mic attenuator and it was maybe better.
  #6
Old 09-22-2011, 04:37 PM
Grim Reaper is on a distinguished road
Default
When using a Turner +3 mic you should talk softly , noise cancelling mics and average mics require harder tones, but not the +3, not sure if you had any previous exp with +3 s
  #7
Old 11-24-2011, 08:22 AM
Tucker442's Avatar
Senior Member
Tucker442 is on a distinguished road
Default
I've had great audio with all Turner mics other than the +2's. I used a hand held expander400 on my 2510 with great reports, also have like 5 or 6 +3, Lafayette Range boost, and +3B's never having a cap issue so really I would look elsewhere for the problem or maybe just try a different power mic
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RF Limited CR-577 Mic Review Robb Meters, Mics & Other Accessories 67 02-21-2014 06:41 AM
Great Mic Sound for your CB or Export Radio-part 3 Robb Installation & Station Setup 4 11-30-2010 11:48 AM
Great Mic Sound for your CB or Export Radio-part 2 Robb Installation & Station Setup 2 10-29-2010 10:27 PM
Used CB Radio: How to Buy-Part 4 Robb General CB Services Discussion 1 12-01-2009 10:31 PM
Turner +2 desk mic Boogieman Tuners, Mics, Meters & other Accessories 10 07-08-2009 09:56 AM
Powered by vBulletin®
