02-11-2012, 11:04 AM
 | Professional Amateur | | Join Date: Apr 2005 Location: Nova Scotia,Canada
Quote:
Originally Posted by Okiksapa Here's what I have so far on this:
1. Fuse is okay
2. DC adjustment knob was loose, tightened that.
3. Hooked up DVM to it and got that following:
- 1.86-1.89 VDC no matter where the voltage adjustment knob was
So - does it look like my voltage adjustment circuitry is bad? It seems so to me. If so, where do I begin to troubleshoot this? What do I test with the DVM? What parts might I need? I'm assuming it will need some soldering to get this fixed.
I appreciate your advice and assistance with this. | Quote:
Originally Posted by Okiksapa I hooked up DVM again and took off the cover to look around.
Nothing seems loose or broken inside.
I did notice that when I rotate the voltage adjustment knob that the DV volts drop from 1.89 to 1.86 when I rotate clockwise. That seems strange, as the volts should increase. |
Sounds to me like the voltage regulator chip is shot. When the voltage regulator takes a dump the typical output voltage is around 2 volts which is what you are seeing. I am pretty sure you need a new LM723 regulator chip. Either that or one of the pass transistors on the heat sink is shorted and allowing too high a voltage to appear on the output and the safety protection is constantly being tripped which limits the output to jst a volt or two. An LM723 regulator chip is just a couple dollars and plugs into a socket and would be easy to replace. The transistor however is a bit harder but not difficult IF you are familiar with electronics.
__________________  |
