Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
Yaesu ft-890 sounds high pitched according to a few people I talked to
Like Tree4Likes
Reply
  #17
Old 02-21-2012, 01:49 PM
mr_fx's Avatar
Senior Member
mr_fx is on a distinguished road
Default
This is getting interesting. I think the previous owner had iit set up for a stock mic and for cutting through a pile up, which it does well with the setting he was using
__________________
QTH: Vert 160/80, Fan 40/20/10, Fan 17/15/12/6, 2m J pole, 2m halos Mobile: 12/15/17/20/40, 10, 6, 2/440
  #18
Old 02-21-2012, 02:09 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
fkurz.net - FT890 / FT840 frequency drift problem
If you have freq drift; then check out the above link.
The owner's manual can be found on this page:
http://pdf.textfiles.com/manuals/SCA...g%20Manual.pdf
I know that newer radios can access the balanced modulator directly thru a connector in the back. This will eliminate audio filtering in the mic preamp stage. Dunno if your radio can do it; but it is worth a shot.
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #19
Old 02-21-2012, 05:10 PM
Senior Member
trucker is on a distinguished road
Default
I have an 890AT (actually two of them) and love it. I use the stock hand mic and also the MD-100A8X desk mic. Both mics sound good from the audio reports I have received. I have even used the MD-100A8X with my Flex 1500 and again, good reports. Yaesu radios, in my experience, tend to sound best with their microphones.
Other brands, are usually a bit flat without some tweaking. The MD-100A8X can be found (used) for around $100 and I consider it a bargin.
trucker
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New Yaesu FTdx 5000 Preview Moleculo HF Bands and HF Rigs 12 02-12-2010 08:23 PM
HELP with HIGH SWR icon on Yaesu FT-900 frostbite HF Bands and HF Rigs 8 05-14-2008 11:19 PM
Powered by vBulletin®
