Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
New MFJ "MightyLite" Switching Power Supplies
Reply
  #1
Old 03-12-2012, 12:58 PM
Moleculo has disabled reputation
Default New MFJ "MightyLite" Switching Power Supplies
I just got this press release about the new line of small form factor variable voltage switching power supplies from MFJ. The 30 amp supply is only 5 inches wide!
Here is the press release:
MFJ MightyLiteTM 30A Metered Switching Power Supply
MFJ-4230MV, $89.95
This is the world’s most compact switching power supply that also has a meter and adjustable voltage control. Just 5Wx21/2H x6D inches, it weighs only 3 lbs. -- it is the perfect pack-n-go power supply for field day, DXpeditions, camping, hiking or to pack for your next business trip or vacation to some far away place.
MFJ-4230MV gives you 25 Amps continuously or 30 Amps surge at 13.8 VDC. The voltage is front-panel adjustable from 4 to 16 Volts. MFJ-4230MV also has a selectable input voltage: choose from 120 or 240 VAC at 47-63 Hz. A simple front-panel push-button switch lets you choose either Ampmeter or Voltmeter -- allows you to select Amps or Volts as you wish to read them.
MFJ-4230MV has an excellent 75% efficiency and extra low ripple and noise, <100 mV. A whisper-quiet fan cools by convection and forced air cooling.
Normal air-flow around the power supply is continuous and a heat sensor increases the fan speed when the temperature rises above 70 degrees Celsius. DC output is five way binding posts on the back of the MFJ-4230MV so you can power your dedicated HF, VHF or UHF transceiver with ease.
MightyLiteTM 28 Amp Switching Power Supply, (no meter), $84.95
MFJ-4128 can power your HF, VHF, or UHF mobile or base transceiver with an output of 28 Amps maximum and 25 Amps continuously at 13.8 VDC. This basic power supply has all of the output connectors you will ever need -- has five way binding posts for high current rigs and quick connectors for low current accessories. It also has a low 7 amperage cigarette lighter plug, perfect for powering small accessories. It is super lightweight (only 4 lbs.) and super-compact 7Wx21/4Hx71/2D inches, so it can still be carried on your business and vacation trips to far away and exotic locations. Features over-voltage and over-current protection systems and has a quiet internal cooling fan with “fan on” LED. Take it worldwide! MFJ-4128 features a selectable AC input voltage from 85 to 135 VAC or from 170-260 VAC -- take it around the world!
MFJ-4230MV and MFJ-4128 areprotected by MFJ’s famous NoMatterWhatTM one year limited warranty. MFJ will repair or replace (at our option) your MFJ antenna no matter what for one complete year.
  #2
Old 03-12-2012, 01:06 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
Nice!
This would go well with my 897!
__________________
Radio-active
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #3
Old 03-12-2012, 01:24 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
made by jetstream ??
http://www.eham.net/reviews/detail/5204
  #4
Old 03-12-2012, 06:23 PM
Default
Could be the same manufacture building different brands, or supplying the cases that are used.
Just like many things.
I used to work for a Company called Hull`s Inc, building Aluminum Boats.
All built by the same people, but depending on the model, and the label put on in the paint shop, It was a Valco Boat, A WestCoaster Boat, Or a BayRunner Boat.
__________________
Radio-active
NASA/SOHO
When I was a child
The child is grown,
The dream is gone.
  #5
Old 03-12-2012, 07:03 PM
74IN's Avatar
Senior Member
74IN is on a distinguished road
Default
I have an Astron switcher, better off with a regulated.
__________________
  #6
Old 03-12-2012, 07:10 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Screw MFJ, get an IOTA and be done with it.
  #7
Old 03-13-2012, 06:29 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
Quote:
What do you mean "Better off with a regulated."? Both switching and linear type supplies are regulated.
__________________
Marriage is like a deck of cards. In the beginning all you need is two hearts and a diamond. By the end you wish you had a club and a spade.
  #8
Old 03-13-2012, 03:54 PM
2RT307's Avatar
Senior Member
2RT307 is on a distinguished road
Default
Quote:
I do love my DLS-55's (I have two of them). But you have to admit, adjustable voltage and a lighted meter would be nice to have. The IOTA's are soooo utilitarian.
73,
RT307
Reply
Bookmarks
Tags
mfj
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Anybody have experiance with the Mean Well line of power supplies? Captain Kilowatt Tuners, Mics, Meters & other Accessories 0 12-16-2011 03:40 PM
TS SWEET 16 or TS VIKING 3200 dxhound Amplifiers 15 04-23-2010 10:13 PM
Power Supply Failure... Robb Installation & Station Setup 7 04-11-2010 11:40 PM
Joining power supplies Copperhead56 Meters, Mics & Other Accessories 2 06-17-2005 03:44 PM
Stacking DC Power supplies ? Moleculo General CB Services Discussion 5 03-16-2005 03:55 AM
Powered by vBulletin®
