| | | Notices | Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar. | Tuners, Mics, Meters & other Accessories
01-13-2008, 06:51 PM
| | Senior Member | | Join Date: Apr 2005 Location: Oklahoma
| | I think that no matter what band you want to play with, the antenna you use should be at least something that'll produce a half way decent signal. An extremely short antenna such as that mobile one (short in relation to wave length) just isn't gonna make much of a signal on the lower HF bands no matter what the power fed to it, within reason. For example, on 160 through something like 20 meters (maybe), feeding that thing a kilowatt would probably have about the same results as using an antenna designed for whatever that frequency is being fed with 100 watts. That's probably sort of a 'stretch', but not by a whole lot...sort of. Less power just means you have to be able to 'work at it' a bit harder, not that it can't be done. If them QRP'ers can do it with miliwatts, you should be able to do it with 100, right?
Get the general and keep going! Then you don't have to remember all them sub-band edges...
- 'Doc |
01-15-2008, 11:07 AM
| | Rf Engineer | | Join Date: Apr 2005 Location: non-cartesian cyberspace
| | "One of the foibles of commercially made tuners in the US is that they are usually rated in 'Pep' rather than average power. So, look for the CW power rating, which will give you a 'real' value to expect or just remember that things are in 'Pep'. {Why is that so? 'Cuz of the advertising of 'bigger' numbers means bigger sales.}"
they're rated for Peak Envelope Power because in any amplitude modulated application the amount of power present at the crest of the envelope can be as much as 2.66 times the measured average power. this applies to both AM and SSB modes of operation. if you want to eliminate any problems regarding limitations then what you want to do is use the minimum amount of inductance and the maximum amount of capacitance required to obtain the necessary match while minimizing network losses. this results in less internal heating and the highest possible output line current. |
08-01-2008, 12:48 AM
| | Member | | Join Date: Dec 2006 Location: Florence Mississippi
| | I use a Johnson Kilowatt Matchbox for my main loop antenna. It doesn't utilize a balun, and has very low loss characteristics. |
08-01-2008, 07:26 AM
| | AC5CH,
Nothing wrong with the ol'Matchbox's made by 'Johnson'! They do have a couple of limitations though, the 'WARC' bands are not exactly 'designed in', since they weren't around when they were made. And since balanced feed lines were still fairly common when they were designed, they didn't have a balun built-in (different design anyway, 'link' coupling and all that). As long as you stick with the bands marked on the dial, it does just fine. Not as much "scootch" room as with tuners using different circuit designs, but lots of thingys that way.
The 'Matchboxes' are big. No miniaturization, which is a good thing as far as I'm concerned. Ah well...
- 'Doc |
08-01-2008, 07:35 AM
| | freecell,
Regardless of the 'why' of it, thinking about tuners being rated in 'Pep' is a very handy way of thinking about it, saves you in most instances from not having a tuner 'big' enough. Especially if 'other' modes besides modulated ones are used.
The thingy about using the least amount of inductance possible is true for any and all tuners, one of 'them' things in knowing how to use them correctly. Lots of possible 'false' tunning settings that are less than the 'best'. Using the least amount of inductance/coil is a good general 'rule' for lots of things, not just tuners. (No intention in opening that can of 'worms'!  )
- 'Doc |
08-01-2008, 06:16 PM
| | Senior Member | | Join Date: Jul 2006 Location: Chatham MI. EN66OG-UP
| | Hello,
I would recomend the Nye Viking MB V A its 1 hell of a Tunner!Ihad 2 going on 10 yrs and never a problem from 160 to 10 mtrs running 1 kw cw -1kw rtty-no arc overs or heating issues unless your loading(tuning weird z-swr-24:1) then it may heat up a bit,you wont have any problems with the L insulator melting tho-The N4XM is a great
tuner also built to order hw you want one-The Nye is no longer made ,but Ive seen them on E-bay going for $400-500 in a 9-9.5 shape,it will handle 4 kw-cw,rtty with no
problem and The N4XM can be ordered to handle 10 kw.Good luck.
Paul -K8PG -CW IS !!!!!
__________________ I ONCE WAS A WORK BEAST
NOW I AM A BRAIN MERCHANT
JACK LONDON |
08-01-2008, 07:19 PM
| | Senior Member | | Join Date: Jun 2006 Location: Staunton, Virginia
| | I use the Palstar AT1K. A little pricey but will tune anything you put into it. Looks good, works flawlessly and put together well
__________________ IC-756 PROII
IC-SP23
IC-PS125
Palstar AT1KP Antenna Tuner
Rigblaster pro
IC-2200H
SM20 Microphone
MD-100 Microphone
Yaesu FT897D
IMAX 2000
Inverted "V' Diploe
4 element 2 Meter beam and Rotator
Astron SS25 |
08-01-2008, 08:25 PM
| | Senior Member | | Join Date: Mar 2007
| | My .02, if you know you like the hobby and are going to stick with it, just get a 3kW rated tuner straight away. Buy it once.
I have the Palstar AT1KM, (now the KP) and it is a nice piece of gear for sure, but now I wish I had the AT4K. Once you start to push a kW through anything....it's always nice to have some headroom.
The AT1KM will handle a reasonably resonant antenna at its power rating, but start to stretch something and it will arc, as will most tuners of lower power ratings. |
08-02-2008, 03:39 AM
| | Hi Doc!
Yep, I love my Matchbox. However, you have a point, the tuning range is limited, and it doesn't work on all of the WARC bands or 160 meters. It is a big, heavy duty duty piece of equipment, though.
I'm going to have to save my pennies up and get one of those Palstar balanced line tuners as they will get a person on 160 meters with high efficiency and are really well made. Folks really seem to like them, too.
Steve |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 02:42 PM. |
