| | | Notices | Put yourself on the GOOGLEME MAP! Feature is also available on the main toolbar. | Tuners, Mics, Meters & other Accessories
06-09-2008, 06:56 AM
|  | Senior Member | | Join Date: Aug 2005 Location: Under a coconut tree in the Carribbean sipping on white rum and coke!!!
| | Astron RS-70A power supply Hello I have A Astron RS-70A power supply. The output Volts is currently 13.8Volts. Is there a pot somewhere inside the power supply to adjust the voltage output? I would like to get 15volts out.
Thanks
__________________
Texas Ranger TR696F SSB
Signal Engineering lightning 6 quad Antenna. |
06-09-2008, 07:37 AM
| | Senior Member | | Join Date: Apr 2005
| | Check your manual. I have the 50 amp models so the adjustment might be the same. With the top off, near the front top is a small horizontal board, on the underside is a small notched half wheel that will allow you to make the adjustment. I'm not sure how much more voltage you will be able to get out of it.
__________________ "To be is to do"-Socrates; "To do is to be"-Sartre; "Do Be Do Be Do"-Sinatra; WV4L, CDX-787, AK2787 Mobile/ Base Icom706MkIIG/ Kenwood TS-2000 w/LDG AT-1000 Stock mic/ D104 w/Heil HC-5 High Sierra 1800Pro w/N2VZ Turbo Tuner,Diamond SG7500/ 40m Horizontal Delta Loop,Wolf .64,Arrow 146-440GP M Force 1000/ Ameritron AL80A |
06-09-2008, 07:46 AM
| | Quote:
Originally Posted by EDUK8TR Check your manual. I have the 50 amp models so the adjustment might be the same. With the top off, near the front top is a small horizontal board, on the underside is a small notched half wheel that will allow you to make the adjustment. I'm not sure how much more voltage you will be able to get out of it. | Ok I will try that.
Thanks
__________________
06-09-2008, 03:22 PM
| | I got home. Unplugged it, took the top off, found the board. I had to discharge the caps and remove the board from the cap. buy removing the two screws. I was able see the thumbwheel and adjust it to get 14.5 volts out. I am happy.
Thanks for the help.
__________________
06-09-2008, 03:40 PM
| | KEWL  !! Glad I was able to help.
06-15-2008, 11:41 AM
|  | Junior Member | | Join Date: Jul 2006
| | Quote:
Originally Posted by Drifter I got home. Unplugged it, took the top off, found the board. I had to discharge the caps and remove the board from the cap. buy removing the two screws. I was able see the thumbwheel and adjust it to get 14.5 volts out. I am happy.
Thanks for the help.  | Let me see.......
Increase of 7/10 of one volt @ 70 amps equals 49 more watts capability
Efficiency of your load, 50%; net difference is 24.5 watts more output.
Getting 25 more watts out of a 100 watt radio, useless!
Running 25 more watts into your previously saturated SS device, senseless.
Man with Golden Screwdriver knowledge, Priceless!
Reason: Amperes
06-15-2008, 12:49 PM
| | Quote:
Man with Golden Screwdriver knowledge, Priceless! | Try not to make unequivocal assumptions as to what he wanted the extra voltage for.
06-16-2008, 03:15 PM
| | Senior Member | | Join Date: Mar 2005 Location: england
| | it would be nice if it was that simple,
about the only thing you can say is he would have 49w less power wasted as heat in the pass transistors @70amp,
we dont know the load impedance, current, voltage transformation ratio or the efficiency of the device been used so anything more is speculation.
__________________  its all about the learning |
06-16-2008, 07:46 PM
| | Senior Member | | Join Date: May 2007 Location: tustin, ca
| | if you're using such a power supply to run a class-C amplifier, you can just tap the DC straight off the big honkin blue capacitor, which bypasses the voltage regulator completely.
The voltage will be unregulated, meaning it could be up to 18volts under no load, and drop down to maybe 15volts under full load. You could never power a radio from that, but a class C amp would be fine with it. You also wouldn't have any loss from the pass transistors since no current is running thru them.
__________________ "Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist |
06-17-2008, 07:17 AM
| | I found that this Astron runs on the warm to hot to the touch side. I have never seen the cooling fan turn on so I went ahead and jumped out the thermostat so the cooling fan runs all the time. Now the power supply stays cool as cucumber.
__________________
Signal Engineering lightning 6 quad Antenna. |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 05:17 PM. |
